FWSM: Strange xlate and lost connectivity
Oct 09, 2007 0 Replies
Hi
I've had some really weird problems with my FWSM after a migration this weekend. The network as set up as seen below, "ApplicationNet" and "UserNet" have the same security level and I have "same security permit intra interface" enabled.
Internet | | FWSM----ApplicationNet | | UserNet
I have a static set up to redirect web traffic to a server on our DMZ, and this is causing me alot of problems. Suddenly the users from the Internet cannot access the web service and neither can anyone on the UserNet. I do a show xlate detail and get the following result
Flags: D - DNS, d - dump, I - identity, i - inside, n - no random, o - outside, r - portmap, s - static
1223 in use, 10418 most used NAT from INTERNET:217.15.245.131 to INTERNET:217.15.245.131 flags Ii
I do a clear xlate on the global IP and the same show command then gives
1168 in use, 10418 most used NAT from DMZ:192.168.144.201 to INTERNET:217.15.245.131 flags si
And once again the web service is accessible. Then later the same day I get the same problem again and can't see anything on the syslogs despite running on debug level.
Whats going on here? /Fredrik
