cisco pix and vlan
May 12, 2006 1 Replies
Hello
I have 2 vlan's
first: inside security 100 (one of hosts: 192.168.1.10) second: caffe security 50 (one of hosts: 192.168.3.10)
I'm trying to allow people from vlan caffe to have access to specific IP (192.168.1.10) on inside
I did:
static (inside,caffe) 192.168.1.10 192.168.3.2 netmask 255.255.255.255 access-list caffe_to_inside permit ip 192.168.3.0 255.255.255.0 host
192.168.1.10 access-group caffe_to_inside in interface caffe
Everything works well but after that people from caffe don't have access to the Internet (outside interface security 0) Nat don't want to work.
Please help me solve my problem.
That indicates that when a host in caffe addresses to 192.168.1.10, that the packet should be forwarded to the inside host 192.168.3.2 . Try reversing the IP addresses.
The pattern is always
static (INTERFACE1,INTERFACE2) IP2 IP1 netmask NETMASK
You could also do:
static (inside,caffee) 192.168.1.10 192.168.1.10 netmask 255.255.255.255
or
access-list nonat_inside permit host 192.168.1.10 192.168.3.0 255.255.255.0 nat (inside) 0 access-list nanat_inside
The differences between these choices have to do with which IP address the inside hosts have to send to, which IP address connections from the inside hosts to the dmz will show up as, and whether proxy-ARP is enabled.
