Multicast inside VLAN
Jul 19, 2005 3 Replies
Jump to replies (3)
Multicast inside VLAN open original image
I'm having some issues with multicast flooding our network. Here is the situation. We use Altiris RapiDeploy, a computer imaging software package, that will unicast to one client (the master client) on a remote network and that master client will then image himself as well as multicast the image to all other clients on the segment. Because of this feature, we do not need any multicast routing. Each site has one multilayer switch (Cisco 3560) that is configured to be the multicast router and cgmp server. Each site also has a mix of Cisco 2950's and
3500's. The 2950's support IGMP Snooping, but the 3500's only support CGMP.
I have set up a test bunch of about 4 machines to re-image to try and figure out what is going on, and so far these are my results.
First I placed all 4 machines on the same switch, a Cisco 3524 which only supports CGMP. Running a sniffer, I notice that all 4 machines send out a IGMP v1 Membership Report for the group 224.2.0.5. I also sniffed the incoming interface on the 3560 which is acting as the router, and verified that the IGMP Membership Reports were reaching it as well. The problem is the 3524 still does not seem to know who is in which group, because I can run "show cgmp" and the group 224.2.0.5 only shows one port, Gi0/2 (The port connecting this switch to the router). However none of the other interfaces that my 4 machines are connected to are showing. So I'm thinking that the either the router is not getting the IGMP messages, therefore not sending out CGMP messages, or it is recieving the IGMP messages and the switch is just not getting the CGMP messages. So back on the 3560 I run the "show ip igmp membership" and I do not see anything for the group 224.2.0.5. I'm not sure if there should be an entry for this group, but I would assume so since there are several other entries for other multicast groups, such as 224.0.1.40, 224.0.1.60, 239.255.255.250, and so on. If I run "debug ip igmp" I never see anything for the 224.2.0.5 group, just all the other groups listed in the "show ip igmp membership". But I can run a "show ip mroute" and I do see a *,224.2.0.5 entry however it's outgoing interface list is Null. There are also routes for each of the 4 machines (Ip of machine, 224.2.0.5). So this tells me that the router knows about the group, but for some reason is not taking the membership reports and sending cgmp updates to the switches.
I may be way in over my head here, but I am trying to give enough information to keep this from being way too long to read. I can be much more specific, but I want to give a brief overview at first and hopefully someone can at least point me in the right direction.
Some additional info, when all 4 machines are left on a CGMP switch, multicast doesn't work, so the imaging server starts a unicast delivery to each client. Obviously not ideal, but still not a major issue. The major issue starts when there is one or more clients on an IGMP snooping capable switch. The 2950, which are capable of IGMP snooping, are correctly identifying the ports to multicast to. Therefore when an image is sent if a client is on this switch a multicast session can be started because the switch correctly sends the multicast traffic to the correct ports. And for some reason, the IGMP switch will send the traffic out all the correct ports as well as the Gi0/2 port. This forwards the traffic to the CGMP enabled switch and since it doesn't have anything in its mac-address-table for that multicast address it floods every port on that switch.
If anyone can offer any help on how best to troubleshoot this issue, I would be more than thankful.
Thanks in advance, Matt
The router config looks like this: (Vlan 170 is what all the machines are in, Vlan 870 is our voice vlan)
.... sniped ...
ip routing ! ip multicast-routing distributed ! ....sniped...
interface GigabitEthernet0/1 no switchport ip address 192.168.1.27 255.255.255.0 no ip mroute-cache ! interface GigabitEthernet0/2 switchport trunk encapsulation dot1q switchport mode trunk ! interface Vlan1 ip address 192.168.170.1 255.255.255.0 no ip mroute-cache ! interface Vlan170 ip address 10.64.170.1 255.255.254.0 ip helper-address 10.64.15.4 ip helper-address 10.64.15.45 ip pim sparse-dense-mode ip cgmp router-only ip mroute-cache distributed ! interface Vlan870 ip address 172.16.170.1 255.255.255.0 ip helper-address 172.16.254.254 no ip mroute-cache ! .... snip ...
ip classless ip route 0.0.0.0 0.0.0.0 192.168.1.1 ip http server ip pim rp-address 192.168.170.1 !
....sniped...
All of the switches have CGMP or IGMP Snooping enabled by default.
Hi Matt,
To filter multicast groups allowed on an interface, use the following command in interface configuration mode:
ip igmp access-group access-list-number-----> Control the multicast groups that hosts on the subnet serviced by an interface can join.
Cisco's Configuring IP Multicast Routing:
Hope this helps.
Brad Reese BradReese.Com Cisco Repair Service Experts
1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 U.S. Toll Free: 877-549-2680 International: 828-277-7272 Website:
Let me ask a follow up question, that might help me understand this a little better. If I have a machine on a 3524, that is sending out v1 IGMP Membership reports, the 3524 is going to forward those on until they reach the router, which in this case is a 3560. The way I understand it is the 3560 (configuration shown in the previous post) should receive the IGMP Membership Report and note that the interface it uses to connect to the 3524 should forward for that group. Then it should broadcast a CGMP message out that same interface with the mac address of the machine and the mac address of the multicast group. The
3524 should hear this message and add a static entry to it's mac address table to forward any packet matching this multicast entry to the port with the machines mac address. If I am correct in how this works, then somewhere the process is breaking down, and I am trying to track down where. In using debug cgmp and debug igmp commands on the 3560, I don't ever see the 3560 acknowledging that it is recieving the IGMP Membership reports. If I run a "show ip igmp membership" on the 3560 I never see the mulitcast group address that my machine is sending and IGMP report for. I'm assuming this is why the router (3560) is not sending out the CGMP messages. Should I see this multicast group in the output of "show ip igmp membership"? If I am not, what other commands can I use to see if the membership reports are being "seen" by the 3560.
Thanks again for all your help, Matt
Turns out the IGMP Membership Reports are not being sent to the correct Destination MAC Address. Rather than sending the IGMP Report to the IP of 224.2.0.5 and Mac of 01.00.5e.02.00.05, it is being sent to
01.00.5e.00.00.01, the all hosts address. Apparently the router uses the source and destination Mac addresses of the IGMP packet it recieves to create the CGMP packet. Therefore the CGMP packet would be a join for the all-hosts group rather than the multicast group we need. The TAC engineer did't believe that a router will send a CGMP packet for the all-hosts group, which is why the CGMP packet wasn't being sent.
