CISCO PIX 501
Sep 16, 2005 2 Replies
CISCO PIX 501 open original image
I have a CISCO PIX 501 that I need to reconfigure. The problem that I have is the last engineer left the device and did not provide the info of the current configuration (IP address, password, ect...)
That is a way to reset the PIX 501 to factory defaults setting with out login to the firewall?
Thank you,
In article , wrote: :I have a CISCO PIX 501 that I need to reconfigure. The problem that I :have is the last engineer left the device and did not provide the info :of the current configuration (IP address, password, ect...)
Search cisco.com for pix password recovery
You may wish to investigate Password Recovery and AAA Configuration Recovery Procedure for the PIX:
as well as Cisco PIX 500 Series Security Appliances Troubleshooting Guides:
and finally Cisco PIX 500 Series Security Appliances Troubleshooting TechNotes:
Hope this helps,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
