cisco 1803 shdsl config problems
Aug 02, 2007 4 Replies
Jump to replies (4)
hey, im configuring my first shdsl router and i am struggling a bit with the configuration. currently the dsl light shows solid green but i cannot access the internet.
heres the show run
sho run
version 12.4 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname router ! boot-start-marker boot-end-marker ! security authentication failure rate 3 log security passwords min-length 6 logging buffered 51200 debugging logging console critical enable secret 5 password no aaa new-model ! resource policy ! clock timezone PCTime 0 clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00 no ip source-route ! ! ip cef ip tcp synwait-time 10 no ip dhcp use vrf connected ip dhcp excluded-address 10.10.10.1 ! ip dhcp pool sdm-pool1 import all network 10.10.10.0 255.255.255.0 default-router 10.10.10.1 ! ! no ip bootp server no ip domain lookup ip domain name yourdomain.com username user privilege 15 secret 5 password ! ! controller DSL 0 mode atm line-term cpe line-mode 2-wire line-zero dsl-mode shdsl symmetric annex B line-rate auto ! ! ! interface FastEthernet0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow shutdown duplex auto speed auto ! interface BRI0 no ip address no ip redirects no ip unreachables no ip proxy-arp encapsulation hdlc ip route-cache flow shutdown ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 ! interface FastEthernet5 ! interface FastEthernet6 ! interface FastEthernet7 ! interface ATM0 no ip address no atm ilmi-keepalive ! interface ATM0.1 point-to-point description $ES_WAN$$FW_OUTSIDE$ ip nat outside no snmp trap link-status pvc 0/38 pppoe-client dial-pool-number 1 ! ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$$ES_LAN$$FW_INSIDE$ ip address 10.10.10.1 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp ip nat inside ip route-cache flow ip tcp adjust-mss 1412 ! interface Dialer0 interface Dialer0 ip address dhcp no ip redirects no ip unreachables no ip proxy-arp ip mtu 1452 encapsulation ppp ip route-cache flow dialer pool 1 dialer-group 1 no cdp enable ppp authentication chap pap callin ppp chap hostname username ppp chap password 7 password ppp pap sent-username username password 7 password ! ! ip http server ip http authentication local ip http timeout-policy idle 60 life 86400 requests 10000 ip nat inside source list 1 interface ATM0.1 overload ! logging trap debugging access-list 1 remark INSIDE_IF=Vlan1 access-list 1 remark SDM_ACL Category=2 access-list 1 permit 10.10.10.0 0.0.0.255 dialer-list 1 protocol ip permit no cdp run ! control-plane ! banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!^C ! line con 0 login local transport output telnet line aux 0 login local transport output telnet line vty 0 4 privilege level 15 login local transport input telnet line vty 5 15 privilege level 15 login local transport input telnet ! scheduler allocate 4000 1000 scheduler interval 500 end
thanks
Alex
< snipped >
I am in the UK and this is PPPoA.
Are you geting an address on Dialer 0?
sh ip int brie
If so then the only problem is your NAT.
ip nat inside source list 1 interface dialer0 overload
Otherwise this may assist.
! This ATM is what we have in a WORKING one
interface ATM0 no ip address ip virtual-reassembly atm ilmi-keepalive pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1
! #### OR IF YOU PREFER ###
interface ATM0 no ip address no atm ilmi-keepalive ! interface ATM0.1 point-to-point description $ES_WAN$$FW_OUTSIDE$ ip nat outside no snmp trap link-status pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1
interface Dialer0 description ip address negotiated !
What other DSL modes are possible here? The 1803 has an SDSL modem, hasn't it? But I'm afraid it's not able to also "talk" ADSSL?
TIA
fw
I haven't seen any DSL router be able to talk SHDSL and ADSL at the same time just by a register change. In general, from what I've seen the controller chips in use are made specific to the application. Ie. the 1803 has a SHDSL controller on it. The 1801 has an ADSL controller on it.
hi, the problem was there was no routing setup so i added a default route (ip route 0.0.0.0 0.0.0.0 dialer0) and now all works fine and as to the actual interface yes that is correct that they are not interchangeable.
Alex
