Cisco 803 routing problem or bridgeing
Apr 03, 2006 0 Replies
Hello
I have set up to Cisco 803 in two locations A and B just like in the below schema
d1 unnum to e0 d1 unnum to e0 C e0 10.1.0.1 A B e0 10.11.0.1 D int_if ext_if int_if 10.11.0.2 ext_if
The D system is the Unix OS which is a gateway to the internet. I want all the systems in A location to connect to the internet through D router which is connected to the Cisco system in location B. Should I use isdn bridging and is it possible to have such setup with Cisco 803 or should I just use proper ip routing entries.
Below I`am attaching config files :
Router in location A: ! ****************************************************************** ! a.cfg - Cisco router configuration file ! Automatically created by Cisco ConfigMaker v2.6 Build 6 ! 3 kwietnia 2006, 11:06:54 ! ! Hostname: a ! Model: 803 ! ****************************************************************** ! service timestamps debug uptime service timestamps log uptime service password-encryption no service tcp-small-servers no service udp-small-servers ! hostname wartin ! enable password lamer username berlin password lamer ! no ip name-server ! isdn switch-type basic-net3 pots country US ! ip subnet-zero no ip domain-lookup ip routing ! interface Dialer 1 description connected to berlin ip unnumbered Ethernet 0 no ip split-horizon encapsulation ppp dialer in-band dialer idle-timeout 120 dialer hold-queue 10 dialer map snapshot 1 name berlin broadcast 0914444444444 dialer map ip 10.11.0.1 name berlin speed 64 broadcast 091444444444 dialer-group 1 ppp authentication chap no ppp multilink snapshot client 15 360 suppress-statechange-update dialer no cdp enable ! interface Ethernet 0 no shutdown description connected to EthernetLAN ip address 10.1.0.1 255.255.255.0 no keepalive ! interface BRI 0 no shutdown description connected to berlin no ip address dialer rotary-group 1 ! ! Dialer Control List 1 ! no dialer-list 1 dialer-list 1 protocol ip permit ! router rip version 2 network 10.0.0.0 no auto-summary ! ! ip classless ! ! IP Static Routes ip route 0.0.0.0 0.0.0.0 Dialer 1 1 no ip http server snmp-server community public RO no snmp-server location no snmp-server contact ! line console 0 exec-timeout 0 0 password login ! line vty 0 4 password login ! end
Router in location B:
! ****************************************************************** ! berlin.cfg - Cisco router configuration file ! Automatically created by Cisco ConfigMaker v2.6 Build 6 ! 3 kwietnia 2006, 11:08:45 ! ! Hostname: berlin ! Model: 803 ! ****************************************************************** ! service timestamps debug uptime service timestamps log uptime service password-encryption no service tcp-small-servers no service udp-small-servers ! hostname berlin ! enable password lamer username wartin password lamer ! no ip name-server ! isdn switch-type basic-net3 pots country US ! ip subnet-zero no ip domain-lookup ip routing ! interface Dialer 1 description connected to a ip unnumbered Ethernet 0 no ip split-horizon encapsulation ppp dialer in-band dialer idle-timeout 120 dialer hold-queue 10 dialer map snapshot 1 name wartin broadcast dialer map ip 10.1.0.1 name wartin speed 64 broadcast 091424444444 dialer-group 1 ppp authentication chap no ppp multilink snapshot server 15 dialer no cdp enable ! interface Ethernet 0 no shutdown description connected to EthernetLAN_1 ip address 10.11.0.1 255.255.255.0 no keepalive ! interface BRI 0 no shutdown description connected to wartin no ip address dialer rotary-group 1 ! ! Dialer Control List 1 ! no dialer-list 1 dialer-list 1 protocol ip permit ! router rip version 2 network 10.0.0.0 no auto-summary ! ! ip classless ! ! IP Static Routes ip route 0.0.0.0 0.0.0.0 Dialer 1 1 no ip http server snmp-server community public RO no snmp-server location no snmp-server contact ! line console 0 exec-timeout 0 0 password login ! line vty 0 4 password login ! end
