Appletalk routing
Mar 16, 2005 3 Replies
Jump to replies (3)
I have a remote router that for some reason isn't broadcasting it's appletalk zone. The remote Mac's do show that they are in that particular routers zone, but that info never makes it over the network. Other zones show up.
Any troubleshooting tips you can provide would be great. The only appletalk routing I know is to make sure the numbers aren't the same on any 2 routers.
It might be worth pointing out that this router *used* to work before we moved that office (yup the whole office). Also worth pointing out is that I do get RIP updates from that location, they are able to browse the internet and get email etc etc, it's only appletalk.
Help!
--Bryan
On the router in that remote office AT-related config may look like this:
hostname router-a ! appletalk routing appletalk route-redistribution ! interface ethernet0 appletalk cable-range 1000-1100 1001.123 appletalk zone ATZoneName ! interface serial0 appletalk cable-range 100-110 101.12 appletalk zone ATZoneName !
On a local router zone/cable-range for serial connection should be rather similar, and cable-range for local LAN should be different:
hostname router-b ! appletalk routing ! interface serial0 appletalk cable-range 100-110 101.234 appletalk zone ATZoneName ! interface ethernet0 appletalk cable-range 2000-2100 2002.111 appletalk zone ATZoneName !
Then use "sh apple route" commands to find out about AT network routes on each side of serial link.
-- andrei
the only noticable difference was the lack of of appletalk route-redistribution, and that my config uses multilink to wrap 2 T1's into a single link.
here's my configs
MAIN ROUTER:
! version 12.2 service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname kent ! no logging console enable secret 5 45lk34lkml3455m44 enable password 7 fsdf4m44mm4434 ! ip subnet-zero ! ! ip name-server 64.1.201.134 ip name-server 64.1.201.135 ! multilink virtual-template 1 appletalk routing appletalk route-redistribution ipx routing 0008.21ed.af60 ! ! ! interface Loopback0 ip address 192.168.210.1 255.255.255.252 ipx network FEED1111 ! interface FastEthernet0/0 description Kent LAN ip address 10.0.0.97 255.255.0.0 duplex auto speed auto appletalk cable-range 1010-1019 1016.79 appletalk zone Kent ipx network 100 encapsulation SAP no mop enabled ! interface Serial0/0 description T1-1 MLP trunk to Bellevue no ip address encapsulation ppp no fair-queue ppp multilink ! interface Serial0/1 description T1 to Mercer Island ip address 192.168.210.5 255.255.255.252 appletalk cable-range 800-800 800.234 appletalk zone Wan MIR no fair-queue ! interface Serial0/2 description T1-2 MLP trunk to Bellevue no ip address encapsulation ppp no fair-queue ppp multilink ! interface Serial0/3 description T1 to Port Angeles ip address 192.168.210.9 255.255.255.252 appletalk cable-range 500-500 500.119 appletalk zone Wan PA ! interface Virtual-Template1 ip unnumbered Loopback0 appletalk cable-range 600-600 600.5 appletalk zone Wan Kent no appletalk route-cache ipx ppp-client Loopback0 ppp multilink ! router rip version 2 redistribute connected redistribute static network 10.0.0.0 network 192.168.210.0 ! ip default-gateway 10.0.0.1 ip classless ip route 0.0.0.0 0.0.0.0 10.0.0.1 ip route 192.168.98.0 255.255.255.0 Serial0/1 ip route 192.233.98.0 255.255.255.0 192.168.210.6 ip route 192.233.99.0 255.255.255.0 Serial0/3 no ip http server no ip pim bidir-enable ! dialer-list 1 protocol ip permit dialer-list 1 protocol ipx permit ! ! ! snmp-server community kent RO banner motd ^C
************************************************ ** Authorized access only ** ************************************************ ^C ! line con 0 exec-timeout 0 0 line aux 0 line vty 0 4 password 7 034555G55G45 login ! no scheduler allocate
And the router that doesn't seem to be working
REMOTE ROUTER: Building configuration...
Current configuration : 1566 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname Bellevue ! enable secret 5 $45G5GG5G5GERG5G54RG545GD enable password 7 453G545G45G4ERG ! ip subnet-zero ! ! ip name-server 64.1.201.134 ip name-server 64.1.201.135 ! multilink virtual-template 1 appletalk routing ipx routing 0008.21ed.bb60 ! ! ! interface Loopback0 ip address 192.168.210.2 255.255.255.252 ipx network FEED1111 ! interface FastEthernet0/0 description Bellevue Lan ip address 10.1.0.97 255.255.255.0 duplex auto speed auto appletalk cable-range 1020-1029 1025.201 appletalk zone Bellevue ipx network FAB encapsulation SAP ! interface Serial0/0 description T1-1 MLP trunk to Kent no ip address encapsulation ppp no ip mroute-cache no fair-queue ppp multilink ! interface Serial0/1 description T1-2 MLP trunk to Kent no ip address encapsulation ppp no fair-queue ppp multilink ! interface Virtual-Template1 ip unnumbered Loopback0 appletalk cable-range 600-600 600.242 appletalk zone Wan Bellevue no appletalk route-cache ipx ppp-client Loopback0 ppp multilink ! router rip version 2 redistribute connected network 10.0.0.0 network 192.168.210.0 ! ip classless ip route 0.0.0.0 0.0.0.0 10.0.0.97 no ip http server no ip pim bidir-enable ! ! ! ! snmp-server community bellevue RO banner motd ^C
********************************************** AUTHORIZED ACCESS ONLY ! ********************************************** ^C ! line con 0 line aux 0 line vty 0 4 password 7 G45G45G45G4G5 login ! end
If an appletalk problem occurs after a move, the first thing you should do is power down EVERY SINGLE appletalk devices INCLUDING print servers.
