Cisco 678 CAP to DMT conversion problem - help!?
Jun 09, 2006 1 Replies
mtin
I finally got my DSL operating over the weekend. The key item was indeed flashing the firmware in my Cisco 678 from CAP to DMT. I used hyperterminal. The session seemed to go per plan, but the first time I had some intersting error lines on bootup: Hello! Checking CBOS Flash…
I tried to flash a Cisco 678 from CAP cbos 2.4.6 to DMT cbos 2.4.6
Yes, I know it is ancient, but in a couple of months my ISP is going to offer wireless, so I don't want to buy a new DSL modem for only a couple months of use.
My session is copied below. the reboot gives errors as listed at the bottom. I used hyperterminal to communicate from the serial port toe the exc port to transfer the nsrouter.c678dmt.full.2.4.6.bin file. That seemed to go fine, but I got errors on reboot.
Any ideas? - Thanks in advance...
transfer/flash session:
Hello! Checking CBOS Flash CRC... MIX header/trailer CRC verified: 0xe226943d
Flash CRC verified: 0x8f81491b Checking Monitor Flash CRC... MIX header/trailer CRC verified: 0x14a39663
Flash CRC verified: 0x55f8936e Checking User Config Flash CRC... MIX header/trailer CRC verified: 0xeace47ae
Flash CRC verified: 0xe8d2f2ea Checking Custom Config Flash CRC... MIX header/trailer not found
Ron960 User Interface: Build 112 (May 30 2002 15:49:05)
NetSpeed HomeRunner(TM); i960 JX Copyright 1997 NetSpeed Corporation Copyright 1998, 1999 Cisco Systems =>es 0 Erasing sector 00000000... Sector erased =>es 1 Erasing sector 00000001... Sector erased =>es 2 Erasing sector 00000002... Sector erased =>es 3 Erasing sector 00000003... Sector erased =>es 4 Erasing sector 00000004... Sector erased =>es 5 Erasing sector 00000005... Sector erased =>df10008000 Downloading CCCCCCCCCCCCCCC -- Download complete -- Transferred 000f7c00 bytes =>pb 10008000 fee00000 000f7c00 Programming flash address 00000000 from 10008000...
Flash programmed =>m0 Monitor already disabled =>rb
Hello! Checking CBOS Flash CRC... MIX header/trailer not found Checking Monitor MIX header/trailer CRC verified: 0x14a39663
Flash CRC verified: 0xe8d2f2ea Checking Custom Config Flash CRC... MIX header/trailer not found Operation fault at fee00000, subtype 01 Fault record is saved at 10001010 fe =>
Invalid command =>rb
Hello! Checking CBOS Flash CRC... MIX header/trailer not found Checking Monitor Flash CRC... MIX header/trailer CRC verified: 0x14a39663 Flash CRC verified: 0x55f8936e Checking User Config Flash CRC... MIX header/trailer CRC verified: 0xeace47ae Flash CRC verified: 0xe8d2f2ea Checking Custom Config Flash CRC... MIX header/trailer not found Operation fault at fee00000, subtype 01 Fault record is saved at 10001010 fee00000 : 00000000 .word 0x00000000 =>
SO I tried the download procredure again and now the modem boots fine
I am surprised that Qwest never > I tried to flash a Cisco 678 from CAP cbos 2.4.6 to DMT cbos 2.4.6 >
