Cisco 678 DSL and PlayStation 2 Adapter
Sep 20, 2004 1 Replies
I'm interested in connecting a PlayStation2 network adapter to my Cisco 678 router to play games online via DSL with my nephew.
It looks like I could hook the 678 to a small hub and run an ethernet cable to the PS2 adapter. Or would I have to unplug the computer and run the cable directly from the 678 router?
Has anyone tried this setup with a 678 yet? If so, how did you hook yours up?
Thanks in advance.
- Scott
I haven't done this but, you can just add a hub. The 678 in ppp mode is a router. You may need to do some things like opening ports on the 678. Check out this web page for some tips on this
. it says Cisco 675 but it applies to 678s as well.
Also, if you currently have the 678 hooked directly to your computer, that is done using a crossover cable (a yellow one comes with the 67xs). You would either hook the crossover cable to an uplink port on you hub or use a regular Ethernet cable hooked to a regular port on a hub between the 678 & the hub.
Kevin
