Cisco 3725 can act as a Voip gateway ?
Nov 05, 2007 4 Replies
Alberto Rubinelli
SIP server is on the internal network, the lan connected directly to Fast Ethernet 0/0 port of the Cisco 3725 Thanks !
I have a Cisco 3725, with a wic 4B-S/T ,4x BRI ISDN It is possible to configure it to act as a gateway for Voip traffic to and from isdn lines ? (using an existing SIP server).
Thanks
Alberto
SIP server is in you premises or on remote area linked with internet
Thanks !
I presume that you will need DSPs.
Definitely no way to do without then with an ISDN Pri.
snipped-for-privacy@hotmail.co.uk ha scritto:
If I add a DSP board to the 3725, I can configure a ISDN gateway with the existing 4B S/T ISND BRI ?
Thanks
