Cisco 1601 cookie required
Feb 28, 2006 0 Replies
Hi all
I have a Cisco 1601 with a completely wiped EEPROM. I managed to get into ROMMON PRIV mode to edit the cookie, and so far I have the Ethernet port working but it doesn't recognise the WAN port yet.
So I need someone with a 1601 and a console cable to get into ROMMON and type > cookie and post the 32 bytes it spits out.
I basically just need the device types (for the first one I'm currently using 0x01 which is shown as (1E), and if I make the second one 0x01 too it shows (unknown) but I end up with the thing thinking it has two Ethernet0 ports wich much ensuing hillarity... So I probably only need the second value.
Thanks!
Retro in South Africa
