hello i got here a new 7960 ip phone i've connected to the network. then i ve made a reset. the phone obtain an ip address from my server and that was all. i cant connect per http , telnet and ssh don't works too. i dont got a terminal cable it seems this requires a special cable (not this with a rj45) in the menue on the phone i cant find options where i can enable the acces per network. as firmware is there the sip firmware with the POS3-o5-3-00 ID in the phone. i wanna use the phone as a standolone device. any ideas what i should make first. or where can i read for the first steps. in google and cisco i cant find the right topics for me. greetings Randolf Balasus
cisci ip phone 7960, what are the first steps of configuration ???
Jun 14, 2005
What do you mean by 'stand-alone device'? How are you handling call-setup? Jonathan
Jonathan
hello thanks for the answer. i wanna use the device as a sip phone without any other components, the phone should stand behind a dsl-router with the connection to the internet. is this possible ? greeting Randolf Balasus
Well, something is going to need to handle call-processing and setup. Usually this is a CallManager, Asterisk, or whatever.
The main point here is that the phone is really stupid. It doesn't even know to play dial-tone when the receiver is picked up, let alone how to get to a destination phone. Something needs to tell it to do that.
If you want to run SIP, that's fine, but a SIP server doesn't have a clue about how to tell a Cisco IP Phone to be a phone.
The simplest solution is CallManagerExpress running on a router, but the cheapest is definitely Asterisk, which runs on a Linux box.
Jonathan
ok i understand. i will set up a asterisk, i got linux servers in the environment, and the phone is a good looking device. greetings Randolf Balasus
