Pix 515 OS7 - VPN Hub and Spoke
Jun 14, 2005 0 Replies
Pix 515 OS7 - VPN Hub and Spoke open original image
I have a network of about 21 pix's (506E's) working on a hub and spoke solution, one of the pix's is not working at all, has anyone had an issue like this? The only odd thing that I see is the tunnel-group for that unit is missing the
tunnel-group (peer ip) general-attributes
and all of the other tunnel-groups have that.... no matter what i do that command will not enter unless I add a radius server or tacacs server to it...but even then the network will not work with the hub and spoke.
I do have connectivity on the same tunnel to the central network though.....any insight to this situation would be helpful....
Thanks,
Mike
---------------------------------------------- Posted with NewsLeecher v1.0 Final * Binary Usenet Leeching Made Easy *
