CHAP for Telnet session?
Aug 04, 2005 2 Replies
www.BradReese.Com
Hi Wynand, command radius-server key Sincerely, Brad Reese Cisco Repair Service Experts Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 U.S. Toll Free: 877-549-2680 International: 828-277-7272
Hi
I am in the process of setting up authentication for telnet sessions via RADIUS to a MS IAS server.
Everything is up and running using PAP where I would prefer using CHAP but can't find any command to facilitate this.
I found loads of references to PPP but PPP is not being used in this instance. Any ideas?
Thanks,
Wynand
Hi Wynand,
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
If you're using Username/Password authentication for telnet sessions, this passes in clear text between the telnet server and client.
If you don't like this, you might use Kerberos or SSH instead.
Aaron
