cisco 803 auth-problem using chap for dsl
Jul 08, 2006 2 Replies
Hello.
First I would like to apologize for my bad English. And for this extensive posting ;-)
And now to the problem: I am trying do establish a DSL-connection using the cisco router 803. Provider: arcor (Germany/Berlin)
Sync etc. is ok. Only there seems to be a problem with the authentication. The provider only supports chap (took me a time to find that out ;-))
The first try to establish a connection is refused: "Authentication failure" The next one (a few seconds later) is apparently OK, but the line is restricted (because of the previous auth-failure):
- not even the gateway can be pinged
- sending a http get request to a arbitrary IP gets only a redirect to
seems to be a "feature" of the provider ;-) Anyway this shows that all technical stuff seem to be OK - only a auth-problem
If anyone is having some suggestions, please post them - I tried a lot, but had no success.
The username/password are really OK ;-) I tried them using a quick setup on a Linux-box (the debug-output of that connection at the end of the posting)
Gratefully for each assistance Klaus
And here some informations and debug output:
#sh ver Cisco Internetwork Operating System Software IOS (tm) C800 Software (C800-K8OSY6-MW), Version 12.3(3a), RELEASE SOFTWARE (fc)Copyright (c) 1986-2003 by cisco Systems, Inc. ... Cisco C803 (MPC850) processor (revision 1) with 51848K bytes of virtual memory.Processor board ID JAD06200L6E (696304404) CPU part number 0x2101 Bridging software. X.25 software, Version 3.0.0. Basic Rate ISDN software, Version 1.1.
2 POTS Ports
1 Ethernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
8M bytes of physical memory (DRAM)
8K bytes of non-volatile configuration memory
8M bytes of flash on board (4M from flash card)
#sh run Building configuration... Current configuration : 1911 bytes ! version 12.3 no service pad service timestamps debug datetime localtime show-timezone service timestamps log datetime localtime show-timezone no service password-encryption ... no aaa new-model ip subnet-zero no ip domain lookup ip name-server 145.253.2.75 ! vpdn enable ! vpdn-group pppoe request-dialin protocol pppoe ip mtu adjust ! isdn switch-type basic-net3 isdn voice-call-failure 0 ! ! interface Ethernet0 description LAN ip address 192.168.0.11 255.255.255.0 ip nat inside ip tcp adjust-mss 1452 pppoe enable pppoe-client dial-pool-number 10 no keepalive ! interface BRI0 ip address negotiated encapsulation ppp shutdown isdn switch-type basic-net3 ppp pap sent-username isdnuser password 0 isdnpass ! interface Dialer0 description ADSL ip address negotiated ip mtu 1488 ip nat outside encapsulation ppp ip tcp adjust-mss 1452 no ip mroute-cache load-interval 30 dialer pool 10 no peer neighbor-route no cdp enable ppp authentication chap callin ppp chap hostname xyzuser ppp chap password 0 xyzpass ppp chap splitnames ! ip nat inside source list 1 interface Dialer0 overload ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 no ip http server no ip http secure-server ! access-list 1 permit any dialer-list 10 protocol ip permit !
debug ppp auth:
*Mar 1 04:08:55 mez: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
Mar 1 04:08:55 mez: Vi1 PPP: Phase is DOWN, Setup
*Mar 1 04:08:55 mez: Vi1 PPP: Using dialer call direction
Mar 1 04:08:55 mez: Vi1 PPP: Treating connection as a callout
*Mar 1 04:08:55 mez: Vi1 PPP: Phase is ESTABLISHING, Active Open
Mar 1 04:08:55 mez: Vi1 PPP: Authorization required
*Mar 1 04:08:55 mez: Vi1 PPP: No remote authentication for call-out
Mar 1 04:08:55 mez: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar 1 04:08:55 mez: Vi1 PPP: No authorization without authentication
Mar 1 04:08:55 mez: Vi1 PPP: Phase is AUTHENTICATING, by the peer
*Mar 1 04:08:55 mez: Vi1 CHAP: I CHALLENGE id 1 len 27 from "blnbr3"
Mar 1 04:08:55 mez: Vi1 CHAP: Using hostname from interface CHAP
*Mar 1 04:08:55 mez: Vi1 CHAP: Using password from interface CHAP
Mar 1 04:08:55 mez: Vi1 CHAP: O RESPONSE id 1 len 33 from "xyzuser"
*Mar 1 04:08:55 mez: Vi1 CHAP: I FAILURE id 1 len 26 msg is "Authentication failure"
Mar 1 04:08:55 mez: Vi1 PPP: Sending Acct Event[Down] id[13]
*Mar 1 04:08:55 mez: Vi1 PPP: Phase is TERMINATING
Mar 1 04:08:55 mez: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
*Mar 1 04:08:55 mez: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down #################################################
Mar 1 04:09:18 mez: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*Mar 1 04:09:18 mez: Vi1 PPP: Phase is DOWN, Setup
Mar 1 04:09:18 mez: Vi1 PPP: Using dialer call direction
*Mar 1 04:09:18 mez: Vi1 PPP: Treating connection as a callout
Mar 1 04:09:18 mez: Vi1 PPP: Phase is ESTABLISHING, Active Open
*Mar 1 04:09:18 mez: Vi1 PPP: Authorization required
Mar 1 04:09:18 mez: Vi1 PPP: No remote authentication for call-out
*Mar 1 04:09:18 mez: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Mar 1 04:09:18 mez: Vi1 PPP: No authorization without authentication
*Mar 1 04:09:18 mez: Vi1 PPP: Phase is AUTHENTICATING, by the peer
Mar 1 04:09:18 mez: Vi1 CHAP: I CHALLENGE id 1 len 27 from "blnbr3"
*Mar 1 04:09:18 mez: Vi1 CHAP: Using hostname from interface CHAP
Mar 1 04:09:18 mez: Vi1 CHAP: Using password from interface CHAP
*Mar 1 04:09:18 mez: Vi1 CHAP: O RESPONSE id 1 len 33 from "xyzuser"
Mar 1 04:09:19 mez: Vi1 CHAP: I SUCCESS id 1 len 42 msg is "CHAP authentication success, unit 9185"
*Mar 1 04:09:19 mez: Vi1 PPP: Phase is FORWARDING, Attempting Forward
Mar 1 04:09:19 mez: Vi1 PPP: Phase is UP
*Mar 1 04:09:19 mez: Vi1 PPP: Process pending packets
Mar 1 04:09:20 mez: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
debug ppp neg:
Mar 1 04:08:55 mez: Vi1 LCP: O CONFREQ [Closed] id 1 len 10
*Mar 1 04:08:55 mez: Vi1 LCP: MagicNumber 0x02C45CEF (0x050602C45CEF)
*Mar 1 04:08:55 mez: Vi1 LCP: I CONFREQ [REQsent] id 164 len 19
Mar 1 04:08:55 mez: Vi1 LCP: MRU 1492 (0x010405D4)
*Mar 1 04:08:55 mez: Vi1 LCP: AuthProto CHAP (0x0305C22305)
Mar 1 04:08:55 mez: Vi1 LCP: MagicNumber 0x57C515EA (0x050657C515EA)
*Mar 1 04:08:55 mez: Vi1 LCP: O CONFNAK [REQsent] id 164 len 8
Mar 1 04:08:55 mez: Vi1 LCP: MRU 1500 (0x010405DC)
*Mar 1 04:08:55 mez: Vi1 LCP: I CONFACK [REQsent] id 1 len 10
*Mar 1 04:08:55 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 165 len 19
*Mar 1 04:08:55 mez: Vi1 LCP: O CONFNAK [ACKrcvd] id 165 len 8
*Mar 1 04:08:55 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 166 len 19
*Mar 1 04:08:55 mez: Vi1 LCP: O CONFNAK [ACKrcvd] id 166 len 8
*Mar 1 04:08:55 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 167 len 19
*Mar 1 04:08:55 mez: Vi1 LCP: O CONFNAK [ACKrcvd] id 167 len 8
*Mar 1 04:08:55 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 168 len 19
*Mar 1 04:08:55 mez: Vi1 LCP: O CONFNAK [ACKrcvd] id 168 len 8
*Mar 1 04:08:55 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 169 len 19
*Mar 1 04:08:55 mez: Vi1 LCP: O CONFREJ [ACKrcvd] id 169 len 8
*Mar 1 04:08:55 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 170 len 15
*Mar 1 04:08:55 mez: Vi1 LCP: MagicNumber 0x57C515EA (0x050657C515EA)
Mar 1 04:08:55 mez: Vi1 LCP: O CONFACK [ACKrcvd] id 170 len 15
*Mar 1 04:08:55 mez: Vi1 LCP: State is Open
*Mar 1 04:08:55 mez: Vi1 PPP: Phase is AUTHENTICATING, by the peer
*Mar 1 04:08:55 mez: Vi1 CHAP: Using hostname from interface CHAP
*Mar 1 04:08:55 mez: Vi1 CHAP: O RESPONSE id 1 len 33 from "xyzuser"
*Mar 1 04:08:55 mez: Vi1 LCP: I TERMREQ [Open] id 171 len 4
Mar 1 04:08:55 mez: Vi1 LCP: O TERMACK [Open] id 171 len 4
*Mar 1 04:08:55 mez: Vi1 PPP: Sending Acct Event[Down] id[13]
*Mar 1 04:08:55 mez: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
*Mar 1 04:09:18 mez: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*Mar 1 04:09:18 mez: Vi1 PPP: Using dialer call direction
*Mar 1 04:09:18 mez: Vi1 PPP: Phase is ESTABLISHING, Active Open
*Mar 1 04:09:18 mez: Vi1 PPP: No remote authentication for call-out
Mar 1 04:09:18 mez: Vi1 LCP: O CONFREQ [Closed] id 1 len 10
*Mar 1 04:09:18 mez: Vi1 LCP: MagicNumber 0x02C4B7A4 (0x050602C4B7A4)
*Mar 1 04:09:18 mez: Vi1 LCP: I CONFREQ [REQsent] id 12 len 19
Mar 1 04:09:18 mez: Vi1 LCP: MRU 1492 (0x010405D4)
*Mar 1 04:09:18 mez: Vi1 LCP: AuthProto CHAP (0x0305C22305)
Mar 1 04:09:18 mez: Vi1 LCP: MagicNumber 0x3ED94705 (0x05063ED94705)
*Mar 1 04:09:18 mez: Vi1 LCP: O CONFNAK [REQsent] id 12 len 8
Mar 1 04:09:18 mez: Vi1 LCP: MRU 1500 (0x010405DC)
*Mar 1 04:09:18 mez: Vi1 LCP: I CONFACK [REQsent] id 1 len 10
*Mar 1 04:09:18 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 13 len 19
*Mar 1 04:09:18 mez: Vi1 LCP: O CONFNAK [ACKrcvd] id 13 len 8
*Mar 1 04:09:18 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 14 len 19
*Mar 1 04:09:18 mez: Vi1 LCP: O CONFNAK [ACKrcvd] id 14 len 8
*Mar 1 04:09:18 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 15 len 19
*Mar 1 04:09:18 mez: Vi1 LCP: O CONFNAK [ACKrcvd] id 15 len 8
*Mar 1 04:09:18 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 16 len 19
*Mar 1 04:09:18 mez: Vi1 LCP: O CONFNAK [ACKrcvd] id 16 len 8
*Mar 1 04:09:18 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 17 len 19
*Mar 1 04:09:18 mez: Vi1 LCP: O CONFREJ [ACKrcvd] id 17 len 8
*Mar 1 04:09:18 mez: Vi1 LCP: I CONFREQ [ACKrcvd] id 18 len 15
*Mar 1 04:09:18 mez: Vi1 LCP: MagicNumber 0x3ED94705 (0x05063ED94705)
Mar 1 04:09:18 mez: Vi1 LCP: O CONFACK [ACKrcvd] id 18 len 15
*Mar 1 04:09:18 mez: Vi1 LCP: State is Open
Mar 1 04:09:19 mez: Vi1 PPP: Queue IPCP code[1] id[165]
*Mar 1 04:09:19 mez: Vi1 PPP: Phase is ESTABLISHING, Finish LCP
*Mar 1 04:09:19 mez: Vi1 IPCP: O CONFREQ [Closed] id 1 len 10
Mar 1 04:09:19 mez: Vi1 IPCP: Address 0.0.0.0 (0x030600000000)
Mar 1 04:09:19 mez: Vi1 IPCP: Redirect packet to Vi1
*Mar 1 04:09:19 mez: Vi1 IPCP: I CONFREQ [REQsent] id 165 len 10
Mar 1 04:09:19 mez: Vi1 IPCP: Address 88.73.0.1 (0x030658490001)
*Mar 1 04:09:19 mez: Vi1 IPCP: O CONFACK [REQsent] id 165 len 10
*Mar 1 04:09:19 mez: Vi1 IPCP: I CONFNAK [ACKsent] id 1 len 10
Mar 1 04:09:19 mez: Vi1 IPCP: Address 88.73.60.119 (0x030658493C77)
*Mar 1 04:09:19 mez: Vi1 IPCP: O CONFREQ [ACKsent] id 2 len 10
*Mar 1 04:09:19 mez: Vi1 IPCP: I CONFACK [ACKsent] id 2 len 10
*Mar 1 04:09:19 mez: Vi1 IPCP: State is Open
Mar 1 04:09:19 mez: Di0 IPCP: Install negotiated IP interface address
88.73.60.119
*Mar 1 04:09:20 mez: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
debug-output of the working pppoe-connection using linux: Jul 7 20:41:42 big pppd[31171]: Plugin rp-pppoe.so loaded. Jul 7 20:41:42 big pppd[31172]: pppd 2.4.3 started by root, uid 0 Jul 7 20:41:42 big pppd[31172]: PADS: Service-Name: '' Jul 7 20:41:42 big pppd[31172]: PPP session is 3954 Jul 7 20:41:42 big pppd[31172]: using channel 3 Jul 7 20:41:42 big pppd[31172]: Using interface ppp0 Jul 7 20:41:42 big pppd[31172]: Connect: ppp0 eth1 Jul 7 20:41:42 big pppd[31172]: Couldn't increase MTU to 1500 Jul 7 20:41:42 big pppd[31172]: Couldn't increase MRU to 1500 Jul 7 20:41:42 big pppd[31172]: sent [LCP ConfReq id=0x1 ] Jul 7 20:41:42 big pppd[31172]: rcvd [LCP ConfReq id=0x22 ] Jul 7 20:41:42 big pppd[31172]: sent [LCP ConfAck id=0x22 ] Jul 7 20:41:42 big pppd[31172]: rcvd [LCP ConfAck id=0x1 ] Jul 7 20:41:42 big pppd[31172]: Couldn't increase MRU to 1500 Jul 7 20:41:42 big pppd[31172]: sent [LCP EchoReq id=0x0 magic=0x3f76e482] Jul 7 20:41:42 big pppd[31172]: rcvd [CHAP Challenge id=0x1 , name = "blnbr3"] Jul 7 20:41:42 big pppd[31172]: sent [CHAP Response id=0x1 , name = "xyzuser"] Jul 7 20:41:42 big pppd[31172]: rcvd [CHAP Success id=0x1 "CHAP authentication success, unit 18339"] Jul 7 20:41:42 big pppd[31172]: CHAP authentication succeeded: CHAP authentication success, unit 18339 Jul 7 20:41:42 big pppd[31172]: peer from calling number
00:30:88:01:66:64 authorized Jul 7 20:41:42 big pppd[31172]: sent [IPCP ConfReq id=0x1 ] Jul 7 20:41:42 big pppd[31172]: rcvd [IPCP ConfReq id=0xbe ] Jul 7 20:41:42 big pppd[31172]: sent [IPCP ConfAck id=0xbe ] Jul 7 20:41:42 big pppd[31172]: rcvd [IPCP ConfNak id=0x1 ] Jul 7 20:41:42 big pppd[31172]: sent [IPCP ConfReq id=0x2 ] Jul 7 20:41:42 big pppd[31172]: rcvd [IPCP ConfAck id=0x2 ] Jul 7 20:41:42 big pppd[31172]: not replacing default route to eth1 [192.168.0.254] Jul 7 20:41:42 big pppd[31172]: Cannot determine ethernet address for proxy ARP Jul 7 20:41:42 big pppd[31172]: local IP address 88.73.131.3 Jul 7 20:41:42 big pppd[31172]: remote IP address 88.73.128.1 Jul 7 20:41:42 big pppd[31172]: primary DNS address 195.50.140.252 Jul 7 20:41:42 big pppd[31172]: secondary DNS address 195.50.140.114 Jul 7 20:41:42 big pppd[31172]: Script /etc/ppp/ip-up started (pid 31180)
solved and posted for the archive:
Just keep smiling and learn to read the debug-output ;-)
!!! CONFNAK mru !!!
That was the problem seems the provider has a broken mtu/mru value setting it manual fixed everything! mtu 1488 !
Thanks anyway ...
