Cisco 1720 12.3(16) CHAP Authen Problem
Apr 04, 2006 1 Replies
Cisco 1720 12.3(16) CHAP Authen Problem open original image
Hello all!
I'm stumped on a CHAP Authen issue.
I have a Cisco 1720 w/ a external USR 56k Modem on the Aux port. The goal is to have the router connect into a Windows RAS server using CHAP authentication. Here is my current config:
chat-script Dialout ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \\T" TIMEOUT
45 CONNECT \\c modemcap entry test:MSC=&F1E0Q0F1&C1&D2S0=0 ! interface Async5 no ip address encapsulation ppp no ip route-cache dialer in-band dialer pool-member 1 async dynamic routing no fair-queue ! interface Dialer1 ip address negotiated ip nat outside encapsulation ppp no ip route-cache dialer pool 1 dialer string 9,1877XXXXXXX modem-script Dialout dialer-group 1 no cdp enable ppp authentication chap ppp chap hostname XXXXXXX ppp chap password 0 XXXXXX ! dialer-list 1 protocol ip permit ! line aux 0 exec-timeout 0 0 script dialer Dialout modem InOut modem autoconfigure type test no exec transport input all stopbits 1 speed 115200 flowcontrol hardware !
When I atempt the connection, the modem dials and handshakes, but Authentication fails. When looking at debug ppp neg and debug ppp authen, I see the following:
*Mar 1 01:47:46.691: As5 CHAP: O CHALLENGE id 45 len 28 from "XXXXX"
Mar 1 01:47:46.895: As5 MS-CHAP-V2: I CHALLENGE id 0 len 33 from "XXXXXX"
*Mar 1 01:47:46.931: As5 MS CHAP V2: Using hostname from interface CHAP
Mar 1 01:47:46.931: As5 MS CHAP V2: Using password from interface CHAP
*Mar 1 01:47:46.931: As5 MS-CHAP-V2: O RESPONSE id 0 len 61 from "XXXXX"
Mar 1 01:47:47.135: As5 MS-CHAP-V2: I FAILURE id 0 len 52 msg is "E=691 R=1 C=8B41DD421538F205006FFB81E710A608 V=3"
On the Windows RAS side, I have also configured the user to authenticate using CHAP or PAP and explicitly disabled MS-CHAP-V2. I am not sure how the CPE decides to start trying to authenticate as MS-CHAP-V2.
On a side note, I have also attempted this into an Astra CVX box and have had the same results. The Astra does not even have the option to MS-CHAP-V2 in its configs.
Any help is appricated.
Note that you can have CHAP configured at one end and MS_CHAP-V2 configured at the other end and authentication should still work. The authentication for each direction should work independently and as long as you have a version of IOS that understands MS-CHAP-V2 things should just work. From your debugs it looks like you do have MS-CHAP-V2 support in your image.
Could you try using MS-CHAP-V2 at the IOS end also and see if that helps? You will have to configure
ppp authentication ms-chap-v2
under the serial interface on the router.
Could it be a mismatched password issue that is causing authentication to fail? Do you have same pre-shared password configured at both ends?
Cisco da Gama
