Catalyst WS-C2822 firmware
Apr 13, 2005 2 Replies
Hi all, I've been lurking for a while just in case this is a FAQ. I have a Catalyst 2820 which has a problem. Two, in fact. One is it has no operational firmware and the second is that it will not accept the V
9.00.04 firmware I have downloaded from Cisco. It simply resets as soon as I initiate an XMODEM session. It has the fast ethernet plug-in, but apart from this it is bog-standard. Is there any way to recover this unit? Does the newer operational firmware need a specific boot firmware to be on the device? Have I even got the correct firmware (cat2820A.9.00.04.bin)? Am I correct in using a null-modem cable to communicate with the serial console?
Any and all help, flames, calling me names because I've made a stupid error etc. welcome and appreciated.
After replacing MattD.. with a small shell script on Wednesday 13 Apr 2005
14:14, the following appeared on stdout:
Looks like I need V5.37 for this beast as it is the old one with a DB9 console port. Any ideas on where to get the file from? Cisco don't have it in their FTP archives any more.
