Can I use 2 VWIC-2MFT cards in 1760 or 26XX as 4 serial interfaces?
Dec 20, 2005 4 Replies
Aman
Please post the sh ver and sh diag .sh diag should tell you what you have on the router. Thanks Aman
Can I use 2 VWIC-2MFT cards in 1760 or 26XX as 4 serial interfaces? open original image
So far, when I plug in two of these cards, the router creates 2 serial interfaces and 2 PRI interfaces...
How can I confince the router that I want 4 serial interfaces for T1 data connections?
Thanks,
Joe McGuckin
Thanks Aman
I tried doing this several months ago and it would not let me use the MFT cards in the VWIC slots in data mode. I ended up using a 2600 series router to support all the interfaces I needed.
Alan
Are both cards the same (model, version)? Maybe the second needs it's card-type set before the interfaces show up.
Erik
