Persistent Loop?
Sep 27, 2006 1 Replies
i,
I am having an issue which looks like a persistent loop.
Check below for how this is setup
Router A has 2 serial interfaces which are 2 T1's which are load sharing per packet Router B has 2 serial interfaces which the 2 T1's connect to and are load sharing per packet
On Router A there is a default route out each interface
ip route 0.0.0.0 0.0.0.0 Serial0/0 ip route 0.0.0.0 0.0.0.0 Serial0/1
When performing traceroute from router a I receive this
#trace 145.97.39.155
Type escape sequence to abort. Tracing the route to rr.knams.wikimedia.org (145.97.39.155)
1 X.X.X.89 72 msec X.X.X.93 36 msec X.X.X.89 4 msec 2 X.X.X.89 !N X.X.X.93 !N * #trace 155.94.60.236
Type escape sequence to abort. Tracing the route to imail-gv6.wyeth.com (155.94.60.236)
1 X.X.X.89 12 msec 8 msec X.X.X.93 8 msec 2 X.X.X.89 !N * X.X.X.93 !N
When tracing from Router B and sourching thr IP address that connects to the other serial on Router A, I can get through..
Anyone have any ideas???
I have been looking into this with a colleague for over 3hours..have tried everything, have not seen anything that doesn't really look right..
Thanks!
Can you do a "show ip route" on both routers?
Doan
