Big problem: Bstun async and TCP IP frame size
Jun 08, 2006 5 Replies
Jump to replies (5)
Big problem: Bstun async and TCP IP frame size open original image
hi all,
I am trying to configure two Cisco 2811 connected between them via LAN and two PCs with Hiperterminal at both extremes (Serial interfaces configured at 19200 bps).
PC1 (Hyperterminal)--------{Serial}--------Cisco
2811--------{LAN}--------Cisco 2811------{Serial}------PC2
I have configured BSTUN encapsulation and async-generic protocol in both routers and it works fine as long as you send characters. I route all the traffic via tcp from PC1 to PC2 and viceversa.
The problem is that I try to send a file using Zmodem and the performance is horrible. As I cannot set a size of frame when the router encapsulates the bytes received through the serial interface. As there is no start-of-frame and end-of-frame characters, I must configure the "asp rx-ift" parameter properly. With a value configured of 40 ms, the maximum PDU size of the frames I can get is 111 bytes.
What I would like to do is to configure the router so that it encapsulates a new TCP/IP frame when a number of bytes collected from the serial interface has been reached. Is there a way or command to set the maximum size of a bstun packet? I have tried "ip mtu" command, but it hasn't had any effect at all. Any idea?
Thank you very much for your attention.
Victor
snipped-for-privacy@hotmail.com skrev:
I have no idea how to do what you ask.
Not entirely sure what you need but maybe these suggestions can help?
-SAto
First of all, thank you very much for your quick answer
SAto ha escrito:
Imagine the scenario I described before. What I want to do is to map every byte received at the Serial0/0/0 of the first router Cisco 2811 to the Serial0/0/0 interface of the second router Cisco 2811.
This can be done thanks to BSTUN tunnels. As there is no local-acknowledge protocol in the interface Serial0/0/0 (in order words, I am receiving a constant byte flow which I must forward to the other router) I have no more option than configuring the protocol "Async-generic". So there is neither address byte nor start-of-frame byte. As I have said before, the only thing I have is a incoming bytes flow entering the router through the Serial0/0/0.
So the router is in charge of collecting these bytes, encapsulate them in a BSTUN TCP/IP packet and send this packet to the other peer, where it will be deencpasulated and the data bytes will be forwarded to the Serial0/0/0 interface of the second router.
the problem I have is that I haven't found out if there is a parameter that controls the number of data bytes encapsulated in each BSTUN TCP/IP packet. I would like to set it to 1000 bytes or so.
Thanks, but I am afraid that it doesn't solve my problem... but thanks for the link!!
Victor,
I think you'd be better off switching from using BSTUN async and going to stream TCP tunneling instead:
Try it with default settings; if you still feel the need to tune, here are some line knobs that you can wiggle:
buffer-length ip tcp input-coalesce-threshold dispatch-timeout
Regards,
Aaron
Aaron Leonard ha escrito:
Thank you Aaron for your contribution!!
But After reading the article, it gives the impression that some kind of local acknowledge or call control mechanism through the RS-232 line is performed by means of sending "CR" and "LF" characters. I am using Hyperterminal because it is the easiest and quickest way to simulate the real device who will send this byte flow through the RS-232 link to the router. This device doesn't admit any connection control character at all.
Moreover, it strikes to me that this approach is more suitable for a scenario where one of the routers generates more traffic in one direction than in the other. However, in the scenario I have to test, both directions are equally loaded.
One more question: the aim of the configuration of these two routers is mapping several async interfaces in one router with the same number of async interfaces in the final router:
Serial0/0 (Router 1) Serial0/0 (Router 2) Serial0/1 (Router 1) Serial0/1 (Router 2) Serial0/2 (Router 1) Serial0/2 (Router 2)
and so on.
I don't see any identifier number similar to "bstun group" parameter in order to perform this mapping. Am I wrong?
Anyway, thank you very much for your reply!!
~ ~ Aaron Leonard ha escrito: ~ ~ > Victor, ~ >
~ > I think you'd be better off switching from using BSTUN async and going ~ > to stream TCP tunneling instead:
~ ~ Thank you Aaron for your contribution!! ~ ~ But After reading the article, it gives the impression that some kind ~ of local acknowledge or call control mechanism through the RS-232 line ~ is performed by means of sending "CR" and "LF" characters.
Not necessarily. "stream TCP" is just raw TCP, with no EOL convention.
~ I am using ~ Hyperterminal because it is the easiest and quickest way to simulate ~ the real device who will send this byte flow through the RS-232 link to ~ the router. This device doesn't admit any connection control character ~ at all. ~ ~ Moreover, it strikes to me that this approach is more suitable for a ~ scenario where one of the routers generates more traffic in one ~ direction than in the other. However, in the scenario I have to test, ~ both directions are equally loaded.
Raw TCP is perfectly capable of handling full duplex traffic.
~ One more question: the aim of the configuration of these two routers is ~ mapping several async interfaces in one router with the same number of ~ async interfaces in the final router: ~ ~ Serial0/0 (Router 1) Serial0/0 (Router 2) ~ Serial0/1 (Router 1) Serial0/1 (Router 2) ~ Serial0/2 (Router 1) Serial0/2 (Router 2) ~ ~ and so on. ~ ~ I don't see any identifier number similar to "bstun group" parameter in ~ order to perform this mapping. Am I wrong?
On the "calling side" line, target the desired "called side" by connecting to the TCP port 4000 + line number.
Best regards,
Aaron
