BGP - route-map matching clients IP.
Sep 05, 2006 2 Replies
Hi all,
I have cisco router connected with BGP to 3 peers. Is it possible to use route-map that will choose (set up) route to specific peer depending on source or destination ip address?
If so I will be gratefull for any example.
Regards, Jarek
sure it is. It's called policy or source-based-routing. You may apply a route-map to one or more of your interfaces like this:
route-map Next-Hop-XY permit 5 match ip address 50 // access-list set ip next-hop a.b.c.d // the bgp peer's IP-address
Then you just assign the route-map to a specific interface like this:
interface ethernet 1/1 port-name ABC ip address ... ip policy route-map Next-Hop-XY
But be careful with that: when the specified peer is down, the source IP will loose worldwide ip-connectivity.
Best regards, Nicolaj Kamensek
Hi Nicolaj,
thanks for explanations. Now all is clear for me.
Jarek
