PLEASE HELP - GRE tunnel
Sep 05, 2006 1 Replies
here is my problem:
I have 3 sites: A, B and C at different locations
For now more than 3 days I have a very bad link from A to C. The providers at A and C are trying to solve the problem but scince we need to work I need a solution for this problem.
The problem occurs only between A and C. Connections between A and B and between B and C are ok.
A is a network equipped with a Cisco 2651 with public IP's available B is a network equipped with a Cisco 2621 with public IP's available C is a Windows 2000 SP4 server (colocation)
Cisco 2651 at A has two FE interfaces (one for LAN and one for WAN which is connected to ISP's router/DSL-Modem)
Cisco 2621 at B has a similar configuration
Server at C is connected to ISP's/hoster's network
At A and B no routing protocols are used, i.e. the routers have only "ip default-gateway" and "ip route 0.0.0.0 0.0.0.0
Hi again,
it seems like the connection problem between site A and server C is solved.
But anyway if anyone could help me build such a configuration for both Ciscos it would be great.
Thanks in advance.
Best regards
Alexej Buchholz
