I'm having a problem to configure V.92 modem on Cisco 1811 to dial-up and stay connected till I power off the router.
[Server(NIC,10.184.60.18/28)] | | [-----------------------------------------] [C1811(FE0,10.184.60.17/28)] [C1811(V.92) ] [-----------------------------------------] | | PSTN
! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname C1811 ! boot-start-marker boot-end-marker ! ! mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 no aaa new-model ip subnet-zero ! ! ip cef ! ! ip ips po max-events 100 no ftp-server write-enable ! ! ! ! ! ! ! interface FastEthernet0 ip address 10.184.60.17 255.255.255.240 ip nat inside ip virtual-reassembly duplex auto speed auto ! interface FastEthernet1 no ip address shutdown duplex auto speed auto ! interface FastEthernet2 no ip address shutdown ! interface FastEthernet3 no ip address shutdown ! interface FastEthernet4 no ip address shutdown ! interface FastEthernet5 no ip address shutdown ! interface FastEthernet6 no ip address shutdown ! interface FastEthernet7 no ip address shutdown ! interface FastEthernet8 no ip address shutdown ! interface FastEthernet9 no ip address shutdown ! interface Vlan1 no ip address ! interface Async1 ip unnumbered FastEthernet0 ip virtual-reassembly encapsulation ppp dialer in-band dialer pool-member 1 async mode dedicated peer default ip address pool 1 ! interface Dialer1 ip address negotiated ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer remote-name SRGSMY01 dialer idle-timeout 0 dialer enable-timeout 5 dialer wait-for-carrier-time 180 dialer string 912345678 dialer hold-queue 80 dialer-group 1 ppp authentication chap ppp chap hostname C3640 ppp chap password 0 cisco ! ip kerberos source-interface FastEthernet0 ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ! ! ip http server no ip http secure-server ! access-list 101 permit ip 10.184.60.0 0.0.0.255 any access-list 101 permit ip 10.184.50.0 0.0.0.255 any dialer-list 1 protocol ip list 101 ! ! ! ! control-plane ! ! line con 0 line 1 modem InOut transport input all autoselect ppp stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 4 login ! no scheduler allocate end
I can't get it works, please help!
