PPPoE on Ethernet Help (Cisco 1800)
Sep 18, 2006 1 Replies
hello,
I need help with my PPPoE on ethernet connection. I configured this through SDM. It tells me that I can establish a PPPoE link ok but I cant ping anything. Here is my config:
I am not sure if I need a vpdn or not any help would be great
Using 2004 out of 196600 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname pmctaiwan ! boot-start-marker boot-end-marker ! no logging buffered enable secret 5 $1$cqaG$9LcrzbO8oI3VEcl5lrs6t0 enable password PmC987 ! no aaa new-model ! resource policy ! ! ! ip cef ! ! ip name-server 139.175.150.20 ! ! ! ! ! ! ! ! ! interface FastEthernet0 description $ETH-WAN$ no ip address duplex auto speed auto pppoe enable pppoe-client dial-pool-number 1 ! interface BRI0 no ip address encapsulation hdlc shutdown isdn point-to-point-setup ! interface FastEthernet1 switchport mode trunk ! interface FastEthernet2 switchport mode trunk ! interface FastEthernet3 switchport mode trunk ! interface FastEthernet4 switchport mode trunk ! interface FastEthernet5 switchport mode trunk ! interface FastEthernet6 switchport mode trunk ! interface FastEthernet7 switchport mode trunk ! interface FastEthernet8 switchport mode trunk ! interface ATM0 no ip address shutdown no atm ilmi-keepalive dsl operating-mode auto ! interface Vlan1 ip address 172.16.96.1 255.255.224.0 ip nat inside ip virtual-reassembly ip tcp adjust-mss 1412 ! interface Dialer0 ip address 211.74.182.77 255.255.255.0 ip mtu 1452 ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 2 ppp authentication pap callin ppp pap sent-username T0298679# password 0 emax6e8x ! router rip redistribute connected network 10.0.0.0 ! ip route 0.0.0.0 0.0.0.0 211.74.182.1 ! ! ip http server no ip http secure-server ip nat inside source list 1 interface Dialer0 overload ! access-list 1 remark INSIDE_IF=Vlan1 access-list 1 remark SDM_ACL Category=2 access-list 1 permit 172.16.96.0 0.0.31.255 dialer-list 1 protocol ip permit dialer-list 2 protocol ip permit ! ! ! ! ! ! control-plane ! ! line con 0 line aux 0 line vty 0 4 password PmC987 login ! ! webvpn context Default_context ssl authenticate verify all ! no inservice ! end
Update:
I fixed the problem. I overlooked the RIP command in my config that provided dynamic Routing for the from subnet.
RobMarsh wrote:
