ASA 5520 Ative/standby failover
Apr 20, 2007 3 Replies
Jump to replies (3)
Hello there,
For failover setup, do we need turn on interface on the secondary unit with no shutdown command?
Here is example from my home work, is there any thing needed to be fixed? any suggestion?
TIA.
Primary Unit Configuration
hostname pixfirewall enable password myenablepassword password mypassword interface GigabitEthernet0/0 security 0 nameif outside ip address 109.23.18.2 255.255.255.0 standby
109.23.18.3 no shutdown interface GigabitEthernet0/1 security 100 nameif inside ip address 10.10.10.1 255.255.192.0 standby
10.10.10.2 no shutdown interface GigabitEthernet0/2 security 40 description LAN Failover Interface no shutdown interface GigabitEthernet0/3 security 50 no shutdown description STATE Failover Interface
telnet 10.10.10.0 255.255.255.0 inside
access-list acl_out permit tcp any host 109.23.18.31 eq 80 failover failover lan unit primary failover lan interface failover GigabitEthernet0/2 ! failover lan enable ! The failover lan enable command is required on the PIX security appliance only. failover polltime unit msec 200 holdtime msec 800 failover key key1 failover link state GigabitEthernet0/3 failover interface ip failover 192.168.254.1
255.255.255.0 standby 192.168.254.2 failover interface ip state 192.168.253.1
255.255.255.0 standby 192.168.253.2 failover mac address GigabitEthernet 0/0 active_Mac Standby_Mac failover mac address GigabitEthernet 0/1 active_Mac Standby_Mac failover replication http
global (outside) 1 109.23.18.5 netmask 255.255.255.0 nat (inside) 1 0.0.0.0 0.0.0.0 static (inside,outside) 109.23.18.31 10.10.10.31 netmask 255.255.255.255 0 0 access-group acl_out in interface outside route outside 0.0.0.0 0.0.0.0 109.23.18.1 1
Example 8: Secondary Unit Configuration failover failover lan unit secondary failover lan interface failover GigabitEthernet0/2 !failover lan enable ! The failover lan enable command is required on the PIX security appliance only. failover key key1 failover interface ip failover 192.168.254.1
Hi.
A in interface that was shutdown would not be able to communicate with it another, so yes.
There is a raft of intformation on Cisco relating to what is and isn't required for configuring failover between ASA's and / or PIX's. A good link is
Clicked send a bit too quickly there :-)
That's what I thought too. I just don't know why Cisco doesn't include it on their Sample Configuration. Thanks. It works great with two ASA
5520 failover. First time I did the configuration.
Cheers.
