Cisco 5520 ASAs with backupisp and Active/Standby failover
May 03, 2010 2 Replies
We currently have 2 ASA 5520s running in Active/Standby failover. We have all 4 NICs being used (Internal, External, DMZ, Failover) on each device and are looking to add another ISP for a backup (using route tracking). The problem i have is there are no more NICs available. I guess I can pruchase the 4 port NIC modules, but they are like $5k each. I could also purchase a layer 2 switch and trunk it to the ASA external interface and separate the external VLANs out that way on the ASA. Im just wondering if anyone has run into this before and what they think the best route to take is in doing this.
Thank you.
You have 1 more NIC available. Management 0/0 is a valid interface and can be used just like any other. Will work just fine for ISP redundancy. You also have the ability to trunk any interface and create as many as you'd like.
Thanks for the help.
I completely forgot about the Mgmt interface. I think im going to use the trunking though.
