ASA 5505 and Cisco Client VPN pass-through
May 05, 2008 2 Replies
With the old PIX v6 multiple Cisco VPN clients on the inside could not reach a remote host. For example, visitors come to your location where you are using a PIX firewall with VPN and they cannot use Cisco Client to VPN to their home office.
Is the ASA 5505 v7.2.3 any better at this?
Thanks!
-Bob
not true - in most cases just badly configured VPNs
Nomatter what box you have, you have the issue, as it lies with IPSEC and not the firewall product...
Problem more than likely that you have seen is the result of people attempting IPSEC tunnels from behind a NAT. As stated this is normally the result of misconfigured (or correctly configured depending on what side your on) firewall.
