ASA 5505 Object-Group
Apr 15, 2008 1 Replies
I am trying to configure an ASA 5505 to allow a range of tcp-udp ports to a host on the inside network. I created the service object-group with the range of ports also I created both tcp and udp access list for the object groups (Cisco ASA and PIX Firewall Handbook). But I need to establish a static route to the host on the inside network. I cannot find the proper syntax to allow this. Any suggestions would be appreciated. I have added the below lines to my configuration.
object-group service test tcp-udp description test port-object range 22345 23344
access-list inbound extended permit tcp any interface outside object-group test access-list inbound extended permit udp any interface outside object-group test
Thanks
If it works like PIX 6 did, it should look like the following:
access-list test_static extended permit tcp host INTERNALIP object-group test any access-list test_static extended permit udp host INTERNALIP object-group test any
static (inside,outside) interface access-list test_static
