Aironet SSID question
Jul 22, 2008 1 Replies
Hi, is it possible to broadcast more than one SSID on a Aironet 1242AG? I'd like to broadcast two networks (separate vlans) one for students and one for teachers.
TIA
Kajetan schrieb:
Yes.
In the Web interface:
Security -> SSID Manager first enable "Set Beacon Mode"/"Multiple BSSID"
Then you can set per selected SSID the "Multiple BSSID Beacon"/"Set SSID as Guest Mode" which enables the SSID broadcasted in the SSID's beacons.
