Cisco Aironet 1200 and ssid
Jul 24, 2006 2 Replies
I've a Cisco Aironet 1200.
The configuration is good.
I have 2 SSID, in 2 différents VLAN with an authentication by radius.
All works fine when i see the wireless network but :
I don't always see the SSID.
Sometime i've see one, sometime the other, sometime none. Never both.
I've test with guest-mode but i can not apply this in 2 SSID (only on one).
What can i do to see both of SSID configure on the AP 1200 ?
Thanks a lot,
Fwed
to make both SSIDs public you have to work with the command "mbssid"
like the following:
dot11 ssid TEST1 mbssid guest-mode
dot11 ssid TEST2 mbssid guest-mode
and then you have to enable mbssid globally on your radio-interface:
interface Dot11Radio0 mbssid ssid TEST1 ssid TEST2
hope that helps
Greetz Eric
Fwed schrieb:
bt snipped-for-privacy@gmx.de a écrit :
Thanks a lot, that's work fine now :D
