AddRoute failed to add a route: code 87
Mar 21, 2007 1 Replies
My wife is trying to connect to her corperate VPN.
She connects ok and can access her email. However she is having trouble accessing some of their bespoke packages.
She has tried all three of our laptops with no joy (all three access our home router wirelessly using 128bit WEP encryption) - work laptop (sony) old work laptop (old sony) and home laptop (dell)
The company and ISP have suggested our ISP are blocking (they aren't and we wouldn't be able to log in if they were - but I checked anyway to be certain) - that there's a problem with the router we have (which hasn't changed config in 12 months and used to work just fine) and all kinds of other stuff not involving them or the PIX firewall.
On checking the cisco client logs we found this
Cisco Systems VPN Client Version 4.8.01.0300 Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved. Client Type(s): Windows, WinNT Running on: 5.1.2600 Service Pack 2 Config file directory: C:\\Program Files\\Cisco Systems\\VPN Client\\
1 07:29:55.468 03/20/07 Sev=Warning/3 GUI/0xA3B0000B Reloaded the Certificates in all Certificate Stores successfully.
2 07:30:07.796 03/20/07 Sev=Warning/2 CVPND/0xE3400013 AddRoute failed to add a route: code 87 Destination 192.168.1.255 Netmask 255.255.255.255 Gateway 175.50.52.133 Interface 175.50.52.133
3 07:30:07.796 03/20/07 Sev=Warning/2 CM/0xA3100024 Unable to add route. Network: c0a801ff, Netmask: ffffffff, Interface: af323485, Gateway: af323485.
The destination is obviously the broadcast address for our local network.
I've tried changing our internal subnet to 192.168.123.0 to see if we had inadvertantly clashed with something on their network 192.168.1.x being a well used default (though she'd been assigned a DHCP pool address by their network of something that didn't clash with our own as far as I could tell - the 175.50.52.133 address above) with no joy.
Has anyone come across this problem and a solution? Initial Google serches haven't proved successful and I want to double check it isn't at our end before going back again to the company's ISP.
Thanks in advance...
What kind of WAP? I know some models will not allow VPNs through over wireless. I had a user in my network have a DLink WAP and come to find out after hours of research, the the model would not allow VPN passthrough. Bought a LinkSys and had no problems.
Also are you doing transparent tunneling, IPSEC over UDP? I believe you had to do that if your WAP is providing NAT/PAT functionality in your network.
