VPN Client not connecting....
Aug 14, 2007 3 Replies
Jump to replies (3)
Systems, Inc./VPN 3000 Concentrator Version 3.5.Rel built by vmurphy on Nov 27 2001 13:35:16
42 11:26:24.390 08/13/07 Sev=Info/4 CM/0x63100019 Mode Config data received
43 11:26:24.406 08/13/07 Sev=Info/4 IKE/0x63000056 Received a key request from Driver: Local IP = 199.245.162.100, GW IP = 199.245.162.35, Remote IP = 0.0.0.0
44 11:26:24.406 08/13/07 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to 199.245.162.35
55 11:26:24.453 08/13/07 Sev=Info/5 IKE/0x63000026 Loaded INBOUND ESP SPI: 0x0BDAFBCA
56 11:26:24.578 08/13/07 Sev=Info/5 CVPND/0x63400013 Destination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 192.168.4.1 192.168.4.193 20 127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1 192.168.4.0 255.255.255.0 192.168.4.193 192.168.4.193 20 192.168.4.193 255.255.255.255 127.0.0.1 127.0.0.1 20 192.168.4.255 255.255.255.255 192.168.4.193 192.168.4.193 20 224.0.0.0 240.0.0.0 192.168.4.193 192.168.4.193 20
255.255.255.255 255.255.255.255 192.168.4.193 192.168.4.193 1
57 11:26:24.593 08/13/07 Sev=Warning/2 CVPND/0xE3400014 The VPN Client could not find the adapters GUID - Virtual Adapter's tcpip GUID failed: 2.
58 11:26:24.593 08/13/07 Sev=Warning/3 CVPND/0xE340000D The Client was unable to enable the Virtual Adapter because it could not set the IP configuration into the registry.
59 11:26:24.593 08/13/07 Sev=Warning/2 CM/0xE310000A The virtual adapter failed to enable
60 11:26:24.593 08/13/07 Sev=Info/5 CVPND/0x63400013 Destination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 192.168.4.1 192.168.4.193 20 127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1 192.168.4.0 255.255.255.0 192.168.4.193 192.168.4.193 20 192.168.4.193 255.255.255.255 127.0.0.1 127.0.0.1 20 192.168.4.255 255.255.255.255 192.168.4.193 192.168.4.193 20 224.0.0.0 240.0.0.0 192.168.4.193 192.168.4.193 20
61 11:26:24.593 08/13/07 Sev=Info/6 CM/0x6310003A Unable to restore route changes from file.
62 11:26:24.593 08/13/07 Sev=Info/6 CM/0x63100037 The routing table was returned to original state prior to Virtual Adapter
63 11:26:24.703 08/13/07 Sev=Warning/2 CVPND/0xE3400014 The VPN Client could not find the adapters GUID - Virtual Adapter's tcpip GUID failed: 2.
88 11:26:25.453 08/13/07 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
89 11:26:25.453 08/13/07 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
90 11:26:25.453 08/13/07 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
91 11:26:25.453 08/13/07 Sev=Info/4 IPSEC/0x6370000A IPSec driver successfully stopped
< end of Log >
This is holding up a major project at my job. If anyone can be of assistance please use my email address....
joe ambrose fabrikant com
thanks in advance.
Any takers on this one?
I really do need an answer...
I haven't come across this particular error before, but a few things spring to mind:
- have you tried re-installing the VPN client on the desktop with admin rights? - do you have any other virtual adapters installed for any other VPN clients or dial-up/usb modems? If so & it's not too much hassle, can you remove them temporarily? - Do you have the option of upgrading to SP2? I'm not sure, but I seem to remember that there were 'issues' with VPNs that might have got better since SP2, with v4.6+? - Can you downgrade again to v3.5 on the desktop?
I did install the client originally with an admin user.
No there were no other virtual devices on the PC.
No, we have software that will not work on SP2.
I did uninstall 4.6, and installed 3.5, it works fine now.
Thanks!
