Add second WIC to 2612XM
Nov 15, 2007 2 Replies
I'm having TWTelecom add a second T1 to our circuit so I need to install a second WIC card in the router. What config issues do I need to be aware of? Is there a doc on configuring a second WIC for bonded T1's? thanks, Carlton.
Depending on how your ISP configuration of the lines are but here is an example:
interface Multilink1 description connected to internet ip address 64.100.200.34 255.255.255.252 no cdp enable ppp multilink ppp multilink fragment disable ppp multilink group 1 ! interface Serial0/0 description multilink 1 interface no ip address encapsulation ppp tx-ring-limit 26 tx-queue-limit 26 no keepalive no fair-queue ppp multilink ppp multilink group 1 ! interface Serial0/1 description multilink 1 interface no ip address encapsulation ppp tx-ring-limit 26 tx-queue-limit 26 no keepalive no fair-queue ppp multilink ppp multilink group 1
For more info google "MultiLink PPP"
You have to match how TWTelecom does it on their end. They have 3 options. Ask them which one they use. :)
