871 configuration question
Jan 11, 2007 4 Replies
Jump to replies (4)
871 configuration question open original image
Hi! I have problem with configuration Cisco 871 router. On attached picture
what i want to accomplish. It's my first contact with Cisco router and it's too difficult for me. I want to have access to the internet on computer 3. how the configuration should look like? It's very important to me. Thanks!
i know that switch will be enough good for it. This configuration is only for education. I dont want to use it everyday.
But why do you need a router there? A simple switch will do.
You will need:-
Choose address range for new subnet
10.1.1.0 255.255.255.0
Choose address for new router on existing subnet
192.168.0.254
router 1 ip route 10.1.1.0 255.255.255.0 192.168.0.254
router 2
int fa 4 ip address 192.168.0.254 255.255.255.0 no shut
int vlan 1
10.1.1.1 255.255.255.0 no shut
ip route 0.0.0.0 0.0.0.0 192.168.0.1
On 871 ports fa 0-3 default to be members of vlan 1.
I'm not sure if i understand you correctly. You wrote: ... router 1 ..... router 2 ...... Should i reconfigure router 1 also?
My actuall config on Cisco 871 is below.
Building configuration...
Current configuration : 3874 bytes ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname yourname ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings ! no aaa new-model ! resource policy ! ip subnet-zero ip cef ! ! no ip dhcp use vrf connected ip dhcp excluded-address 10.10.10.1 ip dhcp excluded-address 10.1.1.51 10.1.1.254 ! ip dhcp pool sdm-pool import all network 10.1.1.0 255.255.255.0 default-router 192.168.0.254 lease 0 2 ! ! no ip domain lookup ip domain name yourdomain.com ! ! crypto pki trustpoint TP-self-signed-3262508828 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-3262508828 revocation-check none rsakeypair TP-self-signed-3262508828 ! ! crypto pki certificate chain TP-self-signed-3262508828 certificate self-signed 01 3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101
04050030 31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274 69666963 6174652D 33323632 35303838 3238301E 170D3036 31323131 31373432 34335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649 4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 32363235 30383832 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100CB76 0F3844EF C1F054A0 E91DABD3 86EBC445 65C77232 E0BEA879 E09C62DB A8F8C7A6 4B024B4E CCE4D6B9 D7201ACE 336ACF0B C5355602 C1E70E8B 09BB72B8 A31FEE9D 459153C9 E1238E71 C564F2DC 2254C2D1 EA755082 CEE6A6EC A1D5A00C C784D573 B2933E0E D2108747 54D76474 536695CB FD69513E CA588EFC 8C68247A 98350203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603 551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D 301F0603 551D2304 18301680 14DB1268 8C677E92 02A0CA99 39F99E93 898AEA43 A5301D06 03551D0E 04160414 DB12688C 677E9202 A0CA9939 F99E9389 8AEA43A5 300D0609 2A864886 F70D0101 04050003 81810085 7E39C7AF 8E40F770 299701DF 74725B2B BAF38A02 0FACDBDF 6CD0083F D112D323 F681A006 4A65D7A4 76F2185E 6AD12F6C 569808DC B5401150 B9B76DEF B9574E53 AC36C885 0B67BB2F 8B87884F 7A95E817 5BC205F4 2FF09CD4 264CC755 B21D0440 5DFFCAF2 8F39827C C88A4682 B91E3356 4D0A1692 2068828F 5727ADA4 702D13 quit username supervisor privilege 15 secret 5 $1$lDO0$oATYvuhX0C.NAMu8hfHtB. ! ! ! ! ! ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 description $ETH-LAN$ ip address 192.168.0.254 255.255.255.0 duplex auto speed auto ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$ ip address 10.1.1.1 255.255.255.0 ip tcp adjust-mss 1452 ! ip classless ip route 0.0.0.0 0.0.0.0 192.168.0.1 ! ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 5 life 86400 requests 10000 ! no cdp run ! ! control-plane ! banner login ^CC
----------------------------------------------------------------------- Cisco Router and Security Device Manager (SDM) is installed on this device. This feature requires the one-time use of the username "cisco" with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI. Here are the Cisco IOS commands.
username privilege 15 secret 0 no username cisco
Replace and with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START GUIDE for your router or go to
^C ! line con 0 login local no modem enable line aux 0 line vty 0 4 privilege level 15 login local transport input telnet ssh ! scheduler max-task-time 5000 end
