7026VXR reload
Jul 31, 2006 5 Replies
Jump to replies (5)
Hi all I face problem with reload the message it is below can somebody help ?
Thanks
router uptime is 1 hour, 50 minutes System returned to ROM by abort at PC 0x60BA50E0 at 18:08:48 EET Wed Jul 26
2006 System restarted at 10:01:08 EET Mon Jul 31 2006 System image file is "disk2:c7200-js-mz.123-16.bin"
cisco 7206VXR (NPE-G1) processor (revision A)
Thanks
  1. did you manually reloaded the router or did it reloade due to the abort ?
  1. what is the value of the config register - post output of show version
Cisco Internetwork Operating System Software IOS (tm) 7200 Software (C7200-JS-M), Version 12.3(16), RELEASE SOFTWARE (fc4) Technical Support:
(c) 1986-2005 by cisco Systems, Inc. Compiled Tue 23-Aug-05 22:48 by ssearch Image text-base: 0x60008AF4, data-base: 0x62064000
ROM: System Bootstrap, Version 12.2(20030826:190624) [BLD-npeg1_rommon_r11
102], DEVELOPMENT SOFTWARE BOOTLDR: 7200 Software (C7200-JS-M), Version 12.3(16), RELEASE SOFTWARE (fc4)
pe-lsf-06 uptime is 1 day, 5 hours, 8 minutes System returned to ROM by abort at PC 0x6072C864 at 18:08:48 EET Wed Jul 26
2006 System restarted at 16:51:21 EET Tue Aug 1 2006 System image file is "disk2:c7200-js-mz.123-16.bin"
cisco 7206VXR (NPE-G1) processor (revision A) with 229376K/32768K bytes of memory. Processor board ID 31525296 SB-1 CPU at 700MHz, Implementation 1, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.7
Last reset from push-button Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). TN3270 Emulation software. Primary Rate ISDN software, Version 1.1. Channelized E1, Version 1.0.
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points. Current configuration on bus mb1 has a total of 90 bandwidth points. This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points. Current configuration on bus mb2 has a total of 0 bandwidth points. This configuration is within the PCI bus capacity and is supported.
Please refer to the following document "Cisco 7200 Series Port Adaptor Hardware Configuration Guidelines" on CCO , for c7200 bandwidth points oversubscription/usage guidelines.
3 Gigabit Ethernet/IEEE 802.3 interface(s) 23 Serial network interface(s) 10 ATM network interface(s) 24 Channelized E1/PRI port(s) 509K bytes of non-volatile configuration memory.
62592K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
:router uptime is 1 hour, 50 minutes :System returned to ROM by abort at PC 0x60BA50E0 at 18:08:48 EET Wed Jul 26 :2006 :System restarted at 10:01:08 EET Mon Jul 31 2006 :System image file is "disk2:c7200-js-mz.123-16.bin"
Manolis Anastasakis wrote:
Cutting out the essentials:
PC 0x60BA50E0 at 18:08:48 PC 0x6072C864 at 18:08:48 ^^^^^^
The various date and time stamps stated above are also appear inconsistent.
If you have a problem with this router please state a clear chronology of events and actions. For example if you reset the router from the reset buttom, please mention it.
I suggest in any case:-
102], DEVELOPMENT SOFTWARE Why are you not running production software? I suggest that you fix that.
(fc4)
As I understand it fc4 means that the software has been released for shippment 3 times and then recalled since there was a show stopper bug discovered. fc4 is a new record for me, not seen that before.
I suggest that you try to find something that has been hacked around a bit less:-)
Should you be rnning a full IOS image for bootstrap and for operation? I think that that will be OK but it seems a bit odd.
