Problems with 7206vxr-npe400
Aug 10, 2007 16 Replies
Jump to replies (16)
Hello, The last month or so we have had some issues with our 7200. All the protocols(LDP,OSPF,sometimes BGP) appear to bounce with dead timers and the CPU goes up to 100%, weird thing is that it happens during off- peak hours (Sunday, early morning weekdays). We are mainly a voice provider with some internet. The router has 4 channelized DS-3s to the DS1 level fully populated and 2 fastethernet uplinks. The fastethernet uplinks show a number of drops with flushes.
the two fast ethernet interfaces (counters were cleared about a day before this): Input queue: 0/150/28287142/77 (size/max/drops/flushes); Total output drops: 0 Input queue: 0/150/987356/1703 (size/max/drops/flushes); Total output drops: 0
xxxx-xxx#show cef drop CEF Drop Statistics Slot Encap_fail Unresolved Unsupported No_route No_adj ChkSum_Err RP 320263 715965 0 88929869
0 0
xxxx-xxxxf#show cef not-cef-switched CEF Packets passed on to next switching layer Slot No_adj No_encap Unsupp'ted Redirect Receive Options Access Frag RP 81 0 0 20 1182639 0
0 0
At first we thought it was an OSPF issue and LDP, BGP were just bouncing because they didn't have route resolution since the routes were not there, but I am pretty sure the protocols bouncing is a bi- product of something else. Any help will be appreciated. thanks
  1. post output of "show version"
  1. when CPU is at 100% are you able to capture output of "show process cpu"
show ver
Cisco Internetwork Operating System Software IOS (tm) 7200 Software (C7200-P-M), Version 12.3(22), RELEASE SOFTWARE (fc2) Technical Support:
(c) 1986-2007 by cisco Systems, Inc. Compiled Wed 24-Jan-07 20:17 by ccai Image text-base: 0x60008AF4, data-base: 0x61A62000
ROM: System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb
117], DEVELOPMENT SOFTWARE BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.1(3a)E5, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) 7200-01sf uptime is 22 weeks, 6 days, 10 hours, 39 minutes System returned to ROM by reload at 22:07:18 PST Fri Mar 2 2007 System restarted at 22:09:26 PST Fri Mar 2 2007 System image file is "disk0:c7200-p-mz.123-22.bin"
cisco 7206VXR (NPE400) processor (revision A) with 229376K/32768K bytes of memory. Processor board ID 20402899 R7000 CPU at 350MHz, Implementation 39, Rev 3.2, 256KB L2 Cache
6 slot VXR midplane, Version 2.1
Last reset from power-on X.25 software, Version 3.0.0. Bridging software. Primary Rate ISDN software, Version 1.1.
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points. Current configuration on bus mb0_mb1 has a total of 580 bandwidth points. This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points. Current configuration on bus mb2 has a total of 380 bandwidth points This configuration is within the PCI bus capacity and is supported.
Please refer to the following document "Cisco 7200 Series Port Adaptor Hardware Configuration Guidelines" on Cisco.com for c7200 bandwidth points oversubscription and usage guidelines.
3 FastEthernet/IEEE 802.3 interface(s) 112 Serial network interface(s) 8 Channelized T1/PRI port(s) 4 Channelized T3 port(s) 125K bytes of non-volatile configuration memory. 46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes). 125440K bytes of ATA PCMCIA card at slot 1 (Sector size 512 bytes). 8192K bytes of Flash internal SIMM (Sector size 256K). Configuration register is 0x102
  1. No, I wish I was able to capture, may put something together to mail me or notify me somehow and run that command.
The fast ethernet link is facing our Datacenter LAN that eventually gets out to the internet and a number of other services. there is about 5 ospf neighbors that are also 7200s running similar load and the same code that are not showing this behavior. We also have about
10 IBGP peers with MBGP running for our L3 vpns, running LDP with all of them.
FYI Cisco has yanked IOS 12.3(22) and replaced it with 12.3(22a). Not that this is related to your issue but just so you are aware.
So how do you recover from this problem or does it just "pass" ?
Can you get any command output from the console while problem is occurring ?
Do you have logging buffer enable on the outer ?
Can you post the output of "show process cpu" as the router is running now ?
Does this router directly face your client's routers ? (i.e could this issue be triggered by something occuring one one of your clients ? _)
BTW Are you seeing a high number of FE interface input drops on the other 7200's.
Dropping 28 million packets over a day or so is not insignificant
It looks to me that you have exceeded the capacity of the routing engine. Having that many drops on the FE interfaces is not good and is a good indication that you just can move that many packets through it. The good news is that a hardware upgrade to an NPE-G1 or G2 should fix this. The NPE-G1 and G2 have 3 10/100/1000 ports on the CPU, which do not take any bandwidth points. In addition the G1 and G2 have a much more efficient routing engine and can move more packets than the NPE-400. What could be happening is that you are exceeding the capacity of the router, and as soon as you hit that point everything falls apart very quickly. Its a very fine line between everything is great, to very bad. We had a similar issue with the NPE-400's, and upgraded them to G1's about 2 years ago, which fixed the problem.
Scott
Scott, I will agree with you for the most part, but why does the problem happen during off peak hours? The router is at about 8-10% load and hardly any traffic is going through it.
Merv, Yes the problem just passes and I can never get to the router fast enough to log any information at the time. I have logging buffer and a syslog server, nothing significant in the logs except for the protocols dropping.
Yes, the router is doing aggregation so it is facing quite a number of clients(about 100) connected with T1s, I also wonder if it has something to do with what they are doing, but no way to verify. I have pondered enabling cflow for traffic analysis but I am a little hesitant due to already mentioned load.
Thanks all for your attention on this.
I would drill down on the cause of the packet drops on the one Fast Ethernet interface
It is quite possilbe that with that rate of input drops that OSPF hellos may get dropped.
Do you have any SNMP polling set up / could setup so that you can see the traffic pattern on the FE interface that has the high drops.
I
Another question, when an "event" occurs how long are the OSPF /BGP adjacencies lost for ?
Do the 7200 FE interfaces connect to a switch or to another router ?
Hi Sal,
Could this be a routing issue, in that the network is re-convirging due to an activity elsewhere and loading up the CPU? We had a similar issue related to this after a new path was implemented and needed to alter a lot of remote interfaces to passive (using EIGRP). Oddly enough, ours was a7206 that was gettig busy as well, however most of the changes were needed at other points in the network. Ours was triggered by a path outage, so was at irregular intervals.
Cheers............pk.
we swapped the router just in case it was some obscure hardware issues. I am not sure how relevant this output will be.
7200-01sf#show int fastEthernet 0/1 switching FastEthernet0/1 Throttle count 0 Drops RP 0 SP 0 SPD Flushes Fast 0 SSE 0 SPD Aggress Fast 0 SPD Priority Inputs 489612 Drops 0
Protocol IP Switching path Pkts In Chars In Pkts Out Chars Out Process 1905096 162263753 128031 9684469 Cache misses 173782 - - - Fast 28735278 2060987087 17013963 1048766613 Auton/SSE 0 0 0 0
Protocol ARP Switching path Pkts In Chars In Pkts Out Chars Out Process 42658 2559480 211 12660 Cache misses 0 - - - Fast 0 0 0 0 Auton/SSE 0 0 0 0
Protocol CDP Switching path Pkts In Chars In Pkts Out Chars Out Process 2773 1117519 2776 885544 Cache misses 0 - - - Fast 0 0 0 0 Auton/SSE 0 0 0 0
Protocol Tag Switching path Pkts In Chars In Pkts Out Chars Out Process 74176 5016615 1480490 139347601 Cache misses 0 - - - Fast 6896360 1937231070 21986498 1281942816 Auton/SSE 0 0 0 0
Protocol Other Switching path Pkts In Chars In Pkts Out Chars Out Process 5547 266256 16643 998580 Cache misses 0 - - - Fast 0 0 0 0 Auton/SSE 0 0 0 0
NOTE: all counts are cumulative and reset only after a reload.
7200-01sf#show int fastEthernet 0/0 switching FastEthernet0/0 Throttle count 0 Drops RP 0 SP 0 SPD Flushes Fast 0 SSE 0 SPD Aggress Fast 0 SPD Priority Inputs 225961 Drops 0
Protocol IP Switching path Pkts In Chars In Pkts Out Chars Out Process 469712 49062608 77598 11343510 Cache misses 1193847 - - - Fast 95373756 2944876303 123468781 4051965715 Auton/SSE 0 0 0 0
Protocol ARP Switching path Pkts In Chars In Pkts Out Chars Out Process 60046 3602760 146 8760 Cache misses 0 - - - Fast 0 0 0 0 Auton/SSE 0 0 0 0
Protocol CDP Switching path Pkts In Chars In Pkts Out Chars Out Process 2775 1121100 2778 911184 Cache misses 0 - - - Fast 0 0 0 0 Auton/SSE 0 0 0 0
Protocol Other Switching path Pkts In Chars In Pkts Out Chars Out Process 5551 266448 16654 999240 Cache misses 0 - - - Fast 0 0 0 0 Auton/SSE 0 0 0 0
Look like a fair amount of ARP traffic.
Is proxy ARP disabled ?
you might want to turn on debug arp brief ly to see where the ARP traffic is coming from
On FA 0/1, almost 2 million packets were process switched versus 28 million being fast switched
Compared to Fa0/0 where there where there were 400K process switch packet versus 95 Million fast siwtched
I would investigate the cause of the amount of process switched traffic on FA 0/1
Please post the output of "show ip traffic"
Here ya go.
7200-01sf#show ip traffic IP statistics: Rcvd: 538424954 total, 10104962 local destination 0 format errors, 0 checksum errors, 12287 bad hop count 0 unknown protocol, 0 not a gateway 0 security failures, 0 bad options, 0 with options Opts: 0 end, 0 nop, 0 basic security, 0 loose source route 0 timestamp, 0 extended security, 0 record route 0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump 0 other Frags: 3070 reassembled, 0 timeouts, 0 couldn't reassemble 33478 fragmented, 66956 fragments, 0 couldn't fragment Bcast: 297215 received, 48800 sent Mcast: 7979209 received, 10234397 sent Sent: 10401304 generated, 526551643 forwarded Drop: 30 encapsulation failed, 0 unresolved, 0 no adjacency 1261409 no route, 0 unicast RPF, 0 forced drop 0 options denied Drop: 0 packets with source IP address zero Drop: 0 packets with internal loop back IP address
ICMP statistics: Rcvd: 0 format errors, 1 checksum errors, 0 redirects, 10 unreachable 56190 echo, 0 echo reply, 0 mask requests, 0 mask replies, 0 quench 0 parameter, 0 timestamp, 0 info request, 0 other 0 irdp solicitations, 0 irdp advertisements Sent: 0 redirects, 154402 unreachable, 0 echo, 56189 echo reply 0 mask requests, 0 mask replies, 0 quench, 0 timestamp 0 info reply, 12289 time exceeded, 0 parameter problem 0 irdp solicitations, 0 irdp advertisements
TCP statistics: Rcvd: 117309 total, 0 checksum errors, 10 no port Sent: 87941 total
UDP statistics: Rcvd: 1954806 total, 0 checksum errors, 5210 no port Sent: 49451 total, 0 forwarded broadcasts
BGP statistics: Rcvd: 35076 total, 9 opens, 0 notifications, 3030 updates 32037 keepalives, 0 route-refresh, 0 unrecognized Sent: 32405 total, 9 opens, 0 notifications, 356 updates 32040 keepalives, 0 route-refresh
OSPF statistics: Rcvd: 11439414 total, 0 checksum errors 4513742 hello, 4646 database desc, 2983 link state req 895360 link state updates, 2559779 link state acks
Sent: 10201357 total
IP-EIGRP statistics: Rcvd: 0 total Sent: 0 total
PIMv2 statistics: Sent/Received Total: 0/0, 0 checksum errors, 0 format errors Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0 Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0 Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0 Queue drops: 0 State-Refresh: 0/0
IGMP statistics: Sent/Received Total: 0/0, Format errors: 0/0, Checksum errors: 0/0, TTL errors:
0/0 Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0 DVMRP: 0/0, PIM: 0/0 Queue drops: 0
ARP statistics: Rcvd: 132679 requests, 204 replies, 0 reverse, 0 other Sent: 204 requests, 249 replies (0 proxy), 0 reverse
I tlooks like there is a fair amount of OSPF traffic.
Is this a single area OSPF network ?
Can you post
sh ip opsf nei sh ip ospf stat
On Aug 14, 3:35 am, Merv wrote:
outputs have been scrubbed
Neighbor ID Pri State Dead Time Address Interface
192.168.1.1 0 FULL/ - 00:00:32 10.1.123.2 Serial4/1/27:0.3 192.40.179.220 0 FULL/ - 00:00:31 10.1.19.2 Serial4/0/25:0.3 10.128.97.2 0 FULL/ - 00:00:35 10.2.23.2 Serial3/1/6:0.3 10.1.2.25 0 FULL/ - 00:00:36 10.1.8.2 Serial3/0/21:0.3 10.100.100.29 0 FULL/ - 00:00:32 10.2.10.2 Serial4/1/2:0.3 192.168.11.199 0 FULL/ - 00:00:33 10.1.56.2 Serial4/0/23:0.3 10.100.100.29 0 FULL/ - 00:00:38 10.1.13.2 Serial3/1/15:0.3 192.168.11.199 0 FULL/ - 00:00:32 10.1.64.2 Serial3/1/14:0.3 192.168.1.7 0 FULL/ - 00:00:35 10.1.26.2 Serial4/0/6:0.3 192.168.8.222 0 FULL/ - 00:00:31 10.1.35.2 Serial4/0/4:0.3 10.4.59.1 1 2WAY/DROTHER 00:00:36 x.x.x.x FastEthernet0/0 x.x.x.x 1 2WAY/DROTHER 00:00:30 x.x.x.x FastEthernet0/0 x.x.x.x 1 2WAY/DROTHER 00:00:31 x.x.x.x FastEthernet0/0 x.x.x.x 1 2WAY/DROTHER 00:00:36 x.x.x.x FastEthernet0/0 x.x.x.x 1 2WAY/DROTHER 00:00:31 x.x.x.x FastEthernet0/0 x.x.x.x 1 FULL/BDR 00:00:39 x.x.x.x FastEthernet0/0 x.x.x.x 1 FULL/DR 00:00:37 x.x.x.x FastEthernet0/0 x.x.x.x 0 FULL/ - 00:00:38 10.2.22.2 Serial4/1/23:0.1 10.2.16.129 0 FULL/ - 00:00:36 10.2.16.2 Serial4/1/17:0.1 10.2.12.129 0 FULL/ - 00:00:36 10.2.12.2 Serial4/1/12:0.1 x.x.x.x 0 FULL/ - 00:00:36 10.2.19.2 Serial4/1/11:0.1 x.x.x.x 0 FULL/ - 00:00:33 10.2.4.2 Serial4/1/6:0.1 x.x.x.x 0 FULL/ - 00:00:36 10.2.3.2 Serial4/1/5:0.1 x.x.x.x 0 FULL/ - 00:00:33 10.2.10.2 Serial4/1/2:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.2.23.2 Serial3/1/6:0.1 x.x.x.x 0 FULL/ - 00:00:36 10.1.123.2 Serial4/1/27:0.1 x.x.x.x 0 FULL/ - 00:00:33 10.1.108.2 Serial4/1/26:0.1 10.1.103.2 0 FULL/ - 00:00:35 10.1.103.2 Serial4/1/25:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.50.2 Serial4/1/22:0.1 10.1.118.2 0 FULL/ - 00:00:35 10.1.118.2 Serial4/1/21:0.1 10.1.49.2 0 FULL/ - 00:00:38 10.1.49.2 Serial4/1/20:0.1 10.1.122.2 0 FULL/ - 00:00:35 10.1.122.2 Serial4/1/19:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.87.2 Serial4/1/18:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.70.2 Serial4/1/16:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.104.2 Serial4/1/15:0.1 x.x.x.x 0 FULL/ - 00:00:33 10.1.113.2 Serial4/1/13:0.1 10.1.116.2 0 FULL/ - 00:00:36 10.1.116.2 Serial4/1/10:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.115.2 Serial4/1/4:0.1 10.1.112.2 0 FULL/ - 00:00:36 10.1.112.2 Serial4/1/3:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.0.2 Serial4/1/1:0.1 10.1.9.129 0 FULL/ - 00:00:35 10.1.9.2 Serial4/0/28:0.1 10.1.16.2 0 FULL/ - 00:00:35 10.1.16.2 Serial4/0/27:0.1 10.1.17.2 0 FULL/ - 00:00:35 10.1.17.2 Serial4/0/26:0.1 10.1.48.129 0 FULL/ - 00:00:35 10.1.48.2 Serial4/0/24:0.1 x.x.x.x 0 FULL/ - 00:00:33 10.1.56.2 Serial4/0/23:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.18.2 Serial4/0/22:0.1 10.1.43.129 0 FULL/ - 00:00:35 10.1.43.2 Serial4/0/21:0.1 10.1.44.129 0 FULL/ - 00:00:38 10.1.44.2 Serial4/0/19:0.1 10.1.46.129 0 FULL/ - 00:00:35 10.1.46.2 Serial4/0/18:0.1 10.1.42.129 0 FULL/ - 00:00:35 10.1.42.2 Serial4/0/17:0.1 x.x.x.x 0 FULL/ - 00:00:38 10.1.40.2 Serial4/0/16:0.1 x.x.x.x 0 FULL/ - 00:00:39 10.1.41.2 Serial4/0/15:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.124.2 Serial4/0/14:0.1 x.x.x.x 0 FULL/ - 00:00:39 10.1.114.2 Serial4/0/13:0.1 10.1.38.129 0 FULL/ - 00:00:37 10.1.38.2 Serial4/0/12:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.15.2 Serial4/0/11:0.1 10.1.20.2 0 FULL/ - 00:00:35 10.1.20.2 Serial4/0/10:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.97.2 Serial4/0/9:0.1 10.1.36.129 0 FULL/ - 00:00:37 10.1.36.2 Serial4/0/5:0.1 10.1.35.129 0 FULL/ - 00:00:35 10.1.35.2 Serial4/0/4:0.1 10.1.34.129 0 FULL/ - 00:00:35 10.1.34.2 Serial4/0/3:0.1 10.1.34.129 0 FULL/ - 00:00:33 10.1.33.2 Serial4/0/2:0.1 10.1.24.2 0 FULL/ - 00:00:35 10.1.24.2 Serial4/0/1:0.1 x.x.x.x 0 FULL/ - 00:00:39 10.1.92.2 Serial3/1/28:0.1 x.x.x.x 0 FULL/ - 00:00:33 10.1.95.2 Serial3/1/25:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.81.2 Serial3/1/21:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.84.2 Serial3/1/20:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.80.2 Serial3/1/19:0.1 x.x.x.x 0 FULL/ - 00:00:37 10.1.13.2 Serial3/1/15:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.64.2 Serial3/1/14:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.71.2 Serial3/1/13:0.1 10.1.117.2 0 FULL/ - 00:00:35 10.1.117.2 Serial3/1/12:0.1 x.x.x.x 0 FULL/ - 00:00:39 10.1.94.2 Serial3/1/11:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.107.2 Serial3/1/10:0.1 x.x.x.x 0 FULL/ - 00:00:39 10.1.96.2 Serial3/1/5:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.10.2 Serial3/1/4:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.27.2 Serial3/1/3:0.1 x.x.x.x 0 FULL/ - 00:00:38 10.1.37.2 Serial3/1/2:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.105.2 Serial3/0/28:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.74.2 Serial3/0/27:0.1 x.x.x.x 0 FULL/ - 00:00:37 10.1.98.2 Serial3/0/26:0.1 10.1.25.2 0 FULL/ - 00:00:36 10.1.25.2 Serial3/0/25:0.1 x.x.x.x 0 FULL/ - 00:00:36 10.1.72.2 Serial3/0/24:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.21.2 Serial3/0/22:0.1 10.1.5.2 0 FULL/ - 00:00:34 10.1.5.2 Serial3/0/20:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.45.2 Serial3/0/18:0.1 x.x.x.x 0 FULL/ - 00:00:37 10.1.1.2 Serial3/0/17:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.79.2 Serial3/0/14:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.22.2 Serial3/0/13:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.76.2 Serial3/0/12:0.1 x.x.x.x 0 FULL/ - 00:00:33 10.1.59.2 Serial3/0/11:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.53.2 Serial3/0/10:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.99.2 Serial3/0/9:0.1 x.x.x.x 0 FULL/ - 00:00:35 10.1.57.2 Serial3/0/8:0.1 x.x.x.x 0 FULL/ - 00:00:38 10.1.110.2 Serial3/0/7:0.1 10.1.52.129 0 FULL/ - 00:00:38 10.1.52.2 Serial3/0/6:0.1 x.x.x.x 0 FULL/ - 00:00:36 10.1.60.2 Serial3/0/5:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.32.2 Serial3/0/4:0.1 x.x.x.x 0 FULL/ - 00:00:36 10.1.75.2 Serial3/0/2:0.1 10.1.63.2 0 FULL/ - 00:00:39 10.1.63.2 Serial3/0/1:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.12.2 Serial4/0/8:0.1 x.x.x.x 0 FULL/ - 00:00:37 10.1.69.9 Serial3/1/8:0.1 x.x.x.x 0 FULL/ - 00:00:37 10.1.69.2 Serial3/0/15:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.8.2 Serial3/0/21:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.101.2 Serial3/1/18:0.1 x.x.x.x 0 FULL/ - 00:00:34 10.1.23.2 Serial4/0/7:0.1 x.x.x.x 0 FULL/ - 00:00:36 10.1.30.2 Serial3/1/1:0.1 x.x.x.x 0 FULL/ - 00:00:36 10.1.89.2 Serial3/1/27:0.1 10.0.0.2 1 2WAY/DROTHER 00:00:37 172.16.253.15 FastEthernet0/1 10.0.0.3 1 2WAY/DROTHER 00:00:35 172.16.253.3 FastEthernet0/1 10.0.0.7 1 2WAY/DROTHER 00:00:31 172.16.253.4 FastEthernet0/1 10.0.0.8 1 FULL/BDR 00:00:30 172.16.253.16 FastEthernet0/1 10.0.0.9 1 2WAY/DROTHER 00:00:30 172.16.253.12 FastEthernet0/1 10.0.0.11 1 2WAY/DROTHER 00:00:34 172.16.253.14 FastEthernet0/1 172.16.253.25 1 FULL/DR 00:00:37 172.16.253.25 FastEthernet0/1 10.2.22.129 0 FULL/ - 00:00:37 10.2.22.2 Serial4/1/23:0.2 10.2.16.2 0 FULL/ - 00:00:31 10.2.16.2 Serial4/1/17:0.2 10.2.12.2 0 FULL/ - 00:00:33 10.2.12.2 Serial4/1/12:0.2 10.2.19.129 0 FULL/ - 00:00:34 10.2.19.2 Serial4/1/11:0.2 10.2.4.2 0 FULL/ - 00:00:30 10.2.4.2 Serial4/1/6:0.2 10.2.4.2 0 FULL/ - 00:00:30 10.2.3.2 Serial4/1/5:0.2 10.2.10.2 0 FULL/ - 00:00:30 10.2.10.2 Serial4/1/2:0.2 10.136.27.2 0 FULL/ - 00:00:33 10.2.23.2 Serial3/1/6:0.2 10.128.71.129 0 FULL/ - 00:00:31 10.1.123.2 Serial4/1/27:0.2 10.1.109.1 0 FULL/ - 00:00:39 10.1.108.2 Serial4/1/26:0.2 10.1.103.129 0 FULL/ - 00:00:33 10.1.103.2 Serial4/1/25:0.2 10.1.50.129 0 FULL/ - 00:00:39 10.1.50.2 Serial4/1/22:0.2 10.1.118.129 0 FULL/ - 00:00:31 10.1.118.2 Serial4/1/21:0.2 10.1.122.129 0 FULL/ - 00:00:34 10.1.122.2 Serial4/1/19:0.2 10.1.87.129 0 FULL/ - 00:00:34 10.1.87.2 Serial4/1/18:0.2 10.1.70.129 0 FULL/ - 00:00:31 10.1.70.2 Serial4/1/16:0.2 10.1.104.129 0 FULL/ - 00:00:30 10.1.104.2 Serial4/1/15:0.2 10.1.115.2 0 FULL/ - 00:00:32 10.1.113.2 Serial4/1/13:0.2 10.1.116.129 0 FULL/ - 00:00:35 10.1.116.2 Serial4/1/10:0.2 10.1.115.2 0 FULL/ - 00:00:32 10.1.115.2 Serial4/1/4:0.2 10.1.112.129 0 FULL/ - 00:00:35 10.1.112.2 Serial4/1/3:0.2 10.1.0.129 0 FULL/ - 00:00:39 10.1.0.2 Serial4/1/1:0.2 10.1.9.2 0 FULL/ - 00:00:35 10.1.9.2 Serial4/0/28:0.2 10.1.16.129 0 FULL/ - 00:00:34 10.1.16.2 Serial4/0/27:0.2 10.1.17.129 0 FULL/ - 00:00:32 10.1.17.2 Serial4/0/26:0.2 10.1.19.2 0 FULL/ - 00:00:30 10.1.19.2 Serial4/0/25:0.2 10.1.48.2 0 FULL/ - 00:00:31 10.1.48.2 Serial4/0/24:0.2 10.1.64.2 0 FULL/ - 00:00:33 10.1.56.2 Serial4/0/23:0.2 10.1.18.129 0 FULL/ - 00:00:39 10.1.18.2 Serial4/0/22:0.2 10.1.43.2 0 FULL/ - 00:00:39 10.1.43.2 Serial4/0/21:0.2 10.1.44.2 0 FULL/ - 00:00:37 10.1.44.2 Serial4/0/19:0.2 10.1.46.2 0 FULL/ - 00:00:32 10.1.46.2 Serial4/0/18:0.2 10.1.42.2 0 FULL/ - 00:00:30 10.1.42.2 Serial4/0/17:0.2 10.1.40.129 0 FULL/ - 00:00:37 10.1.40.2 Serial4/0/16:0.2 10.3.13.2 0 FULL/ - 00:00:38 10.1.41.2 Serial4/0/15:0.2 10.1.124.129 0 FULL/ - 00:00:37 10.1.124.2 Serial4/0/14:0.2 10.1.114.129 0 FULL/ - 00:00:38 10.1.114.2 Serial4/0/13:0.2 10.1.38.2 0 FULL/ - 00:00:37 10.1.38.2 Serial4/0/12:0.2 10.1.15.129 0 FULL/ - 00:00:32 10.1.15.2 Serial4/0/11:0.2 10.1.20.129 0 FULL/ - 00:00:31 10.1.20.2 Serial4/0/10:0.2 10.1.97.129 0 FULL/ - 00:00:35 10.1.97.2 Serial4/0/9:0.2 10.1.12.129 0 FULL/ - 00:00:31 10.1.12.2 Serial4/0/8:0.2 10.1.26.2 0 FULL/ - 00:00:34 10.1.26.2 Serial4/0/6:0.2 10.1.36.2 0 FULL/ - 00:00:36 10.1.36.2 Serial4/0/5:0.2 10.1.35.2 0 FULL/ - 00:00:39 10.1.35.2 Serial4/0/4:0.2 10.1.34.2 0 FULL/ - 00:00:32 10.1.34.2 Serial4/0/3:0.2 10.1.34.2 0 FULL/ - 00:00:32 10.1.33.2 Serial4/0/2:0.2 10.1.24.129 0 FULL/ - 00:00:39 10.1.24.2 Serial4/0/1:0.2 10.1.92.129 0 FULL/ - 00:00:38 10.1.92.2 Serial3/1/28:0.2 10.1.95.2 0 FULL/ - 00:00:37 10.1.95.2 Serial3/1/25:0.2 10.1.80.2 0 FULL/ - 00:00:34 10.1.81.2 Serial3/1/21:0.2 10.1.84.129 0 FULL/ - 00:00:30 10.1.84.2 Serial3/1/20:0.2 10.1.80.2 0 FULL/ - 00:00:34 10.1.80.2 Serial3/1/19:0.2 10.1.93.2 0 FULL/ - 00:00:39 10.1.93.2 Serial3/1/17:0.2 10.2.10.2 0 FULL/ - 00:00:39 10.1.13.2 Serial3/1/15:0.2 10.1.64.2 0 FULL/ - 00:00:30 10.1.64.2 Serial3/1/14:0.2 10.1.71.0 0 FULL/ - 00:00:35 10.1.71.2 Serial3/1/13:0.2 10.1.117.129 0 FULL/ - 00:00:35 10.1.117.2 Serial3/1/12:0.2 10.1.95.2 0 FULL/ - 00:00:39 10.1.94.2 Serial3/1/11:0.2 10.1.107.129 0 FULL/ - 00:00:30 10.1.107.2 Serial3/1/10:0.2 10.1.96.129 0 FULL/ - 00:00:39 10.1.96.2 Serial3/1/5:0.2 10.1.10.2 0 FULL/ - 00:00:39 10.1.10.2 Serial3/1/4:0.2 10.1.27.2 0 FULL/ - 00:00:33 10.1.27.2 Serial3/1/3:0.2 10.1.37.2 0 FULL/ - 00:00:38 10.1.37.2 Serial3/1/2:0.2 10.1.105.129 0 FULL/ - 00:00:30 10.1.105.2 Serial3/0/28:0.2 10.1.74.2 0 FULL/ - 00:00:39 10.1.74.2 Serial3/0/27:0.2 10.1.98.129 0 FULL/ - 00:00:36 10.1.98.2 Serial3/0/26:0.2 10.1.25.129 0 FULL/ - 00:00:38 10.1.25.2 Serial3/0/25:0.2 10.1.72.129 0 FULL/ - 00:00:35 10.1.72.2 Serial3/0/24:0.2 10.1.21.129 0 FULL/ - 00:00:36 10.1.21.2 Serial3/0/22:0.2 10.1.5.129 0 FULL/ - 00:00:31 10.1.5.2 Serial3/0/20:0.2 10.1.45.2 0 FULL/ - 00:00:32 10.1.45.2 Serial3/0/18:0.2 10.1.1.2 0 FULL/ - 00:00:38 10.1.1.2 Serial3/0/17:0.2 10.1.79.129 0 FULL/ - 00:00:31 10.1.79.2 Serial3/0/14:0.2 10.1.22.129 0 FULL/ - 00:00:31 10.1.22.2 Serial3/0/13:0.2 10.1.76.129 0 FULL/ - 00:00:32 10.1.76.2 Serial3/0/12:0.2 10.1.59.2 0 FULL/ - 00:00:32 10.1.59.2 Serial3/0/11:0.2 10.1.59.2 0 FULL/ - 00:00:32 10.1.53.2 Serial3/0/10:0.2 10.1.99.129 0 FULL/ - 00:00:30 10.1.99.2 Serial3/0/9:0.2 10.4.33.2 0 FULL/ - 00:00:34 10.1.57.2 Serial3/0/8:0.2 10.1.110.129 0 FULL/ - 00:00:37 10.1.110.2 Serial3/0/7:0.2 10.1.52.2 0 FULL/ - 00:00:32 10.1.52.2 Serial3/0/6:0.2 10.1.60.2 0 FULL/ - 00:00:36 10.1.60.2 Serial3/0/5:0.2 10.1.32.129 0 FULL/ - 00:00:39 10.1.32.2 Serial3/0/4:0.2 10.1.54.2 0 FULL/ - 00:00:37 10.1.54.2 Serial3/0/3:0.2 10.1.75.129 0 FULL/ - 00:00:36 10.1.75.2 Serial3/0/2:0.2 10.1.63.129 0 FULL/ - 00:00:39 10.1.63.2 Serial3/0/1:0.2 10.1.49.129 0 FULL/ - 00:00:37 10.1.49.2 Serial4/1/20:0.2 10.1.69.2 0 FULL/ - 00:00:37 10.1.69.9 Serial3/1/8:0.2 10.1.69.2 0 FULL/ - 00:00:37 10.1.69.2 Serial3/0/15:0.2 10.1.8.2 0 FULL/ - 00:00:34 10.1.8.2 Serial3/0/21:0.2 10.0.82.129 0 FULL/ - 00:00:36 10.1.101.2 Serial3/1/18:0.2 10.0.13.2 0 FULL/ - 00:00:34 10.1.23.2 Serial4/0/7:0.2 10.128.91.2 0 FULL/ - 00:00:36 10.1.30.2 Serial3/1/1:0.2 10.136.14.2 0 FULL/ - 00:00:36 10.1.89.2 Serial3/1/27:0.2 7200-01sf#show ip os 7200-01sf#show ip ospf st 7200-01sf#show ip ospf sta 7200-01sf#show ip ospf ? Process ID number border-routers Border and Boundary Router Information database Database summary flood-list Link state flood list interface Interface information mpls MPLS related information neighbor Neighbor list request-list Link state request list retransmission-list Link state retransmission list sham-links Sham link information summary-address Summary-address redistribution Information virtual-links Virtual link information | Output modifiers
7200-01sf#show ip ospf stat Area 0: SPF algorithm executed 4 times
SPF calculation time Delta T Intra D-Intra Summ D-Summ Ext D-Ext Total Reason
03:35:38 8 8 0 8 8 0 40 R, SN, X 03:35:27 0 0 0 0 12 0 12 X 03:08:13 0 0 0 0 0 0 0 X 03:08:13 0 0 0 0 12 0 12 X 03:08:03 0 0 0 0 0 0 0 X 03:06:45 0 0 0 0 12 0 12 X 03:06:45 0 0 0 0 0 0 0 X 03:06:35 0 0 0 0 12 0 12 X 03:06:35 0 0 0 0 0 0 0 X 01:57:00 0 0 0 0 0 0 0 X
Area 0: SPF algorithm executed 8 times
Area 0: SPF algorithm executed 122 times Area 1: SPF algorithm executed 197 times Area 5002: SPF algorithm executed 5 times Area 5005: SPF algorithm executed 8 times Area 5006: SPF algorithm executed 4 times Area 5007: SPF algorithm executed 4 times Area 5008: SPF algorithm executed 2 times Area 5009: SPF algorithm executed 5 times Area 5010: SPF algorithm executed 4 times Area 5017: SPF algorithm executed 2 times Area 5018: SPF algorithm executed 3 times Area 5020: SPF algorithm executed 7 times
Area 0: SPF algorithm executed 121 times Area 1: SPF algorithm executed 202 times Area 5005: SPF algorithm executed 11 times Area 5006: SPF algorithm executed 6 times Area 5007: SPF algorithm executed 5 times Area 5008: SPF algorithm executed 4 times Area 5009: SPF algorithm executed 6 times Area 5010: SPF algorithm executed 5 times Area 5017: SPF algorithm executed 4 times Area 5018: SPF algorithm executed 5 times Area 5020: SPF algorithm executed 5 times
7200-01sf#show run | b router ospf router ospf 100 log-adjacency-changes area 1 range 10.1.0.0 x.x.x.x area 1 range 10.2.0.0 x.x.x.x area 5005 range 10.1.69.0 x.x.x.x area 5006 range 10.1.100.0 x.x.x.x area 5007 range 10.1.8.0 x.x.x.x area 5008 range 10.1.90.0 x.x.x.x area 5009 range 10.1.101.0 x.x.x.x area 5010 range 10.1.23.0 x.x.x.x area 5017 range 10.3.6.0 x.x.x.x area 5018 range 10.1.30.0 x.x.x.x area 5020 range 10.1.89.0 x.x.x.x network 10.0.0.0 0.0.0.255 area 0 network 10.1.8.0 0.0.0.255 area 5007 network 10.1.23.0 0.0.0.255 area 5010 network 10.1.30.0 0.0.0.255 area 5018 network 10.1.49.0 0.0.0.255 area 1 network 10.1.69.0 0.0.0.255 area 5005 network 10.1.89.0 0.0.0.255 area 5020 network 10.1.90.0 0.0.0.255 area 5008 network 10.1.100.0 0.0.0.255 area 5006 network 10.1.101.0 0.0.0.255 area 5009 network 10.1.0.0 0.0.255.255 area 1 network 10.2.0.0 0.0.31.255 area 1 network 10.3.6.0 0.0.0.255 area 5017 network 172.16.0.0 0.0.255.255 area 0 ! router ospf 101 vrf vrfNONAME log-adjacency-changes area 1 range 10.1.0.0 x.x.x.x area 1 range 10.2.0.0 x.x.x.x area 5005 range 10.1.69.0 x.x.x.x area 5006 range 10.1.100.0 x.x.x.x area 5007 range 10.1.8.0 x.x.x.x area 5008 range 10.1.90.0 x.x.x.x area 5009 range 10.1.101.0 x.x.x.x area 5010 range 10.1.23.0 x.x.x.x area 5017 range 10.3.6.0 x.x.x.x area 5018 range 10.1.30.0 x.x.x.x area 5020 range 10.1.89.0 x.x.x.x redistribute static subnets network 10.1.8.0 0.0.0.255 area 5007 network 10.1.12.0 0.0.0.255 area 5002 network 10.1.23.0 0.0.0.255 area 5010 network 10.1.30.0 0.0.0.255 area 5018 network 10.1.69.0 0.0.0.255 area 5005 network 10.1.89.0 0.0.0.255 area 5020 network 10.1.90.0 0.0.0.255 area 5008 network 10.1.100.0 0.0.0.255 area 5006 network 10.1.101.0 0.0.0.255 area 5009 network 10.1.0.0 0.0.255.255 area 1 network 10.2.0.0 0.0.31.255 area 1 network 10.3.6.0 0.0.0.255 area 5017 network 10.0.0.0 0.255.255.255 area 0 network x.x.x.x 0.0.0.0 area 0 network x.x.x.x 0.255.255.255 area 0 ! router ospf 102 vrf vrfNONAME log-adjacency-changes redistribute static subnets network 10.0.0.0 0.255.255.255 area 0 ! router ospf 103 vrf vrfNONAME log-adjacency-changes redistribute static subnets redistribute bgp 65520 subnets network 10.0.0.0 0.255.255.255 area 0 ! router ospf 104 vrf vrfNONAME log-adjacency-changes redistribute static subnets network 10.0.0.0 0.255.255.255 area 0 ! router ospf 105 vrf vrfNONAME log-adjacency-changes redistribute static subnets redistribute bgp 65520 subnets network 10.0.0.0 0.255.255.255 area 0 ! router ospf 106 vrf vrfNONAME log-adjacency-changes redistribute static subnets redistribute bgp 65520 subnets network 10.0.0.0 0.255.255.255 area 0 network 0.0.0.0 x.x.x.x area 0 ! router ospf 107 vrf vrfNONAME log-adjacency-changes redistribute static subnets redistribute bgp 65520 subnets network 10.0.0.0 0.255.255.255 area 0 ! router bgp 65520 no synchronization bgp log-neighbor-changes neighbor mbgp peer-group neighbor mbgp remote-as 65520 neighbor mbgp update-source Loopback0 neighbor 10.0.0.1 peer-group mbgp neighbor 10.0.0.2 peer-group mbgp neighbor 10.0.0.3 peer-group mbgp neighbor 10.0.0.5 peer-group mbgp neighbor 10.0.0.6 peer-group mbgp neighbor 10.0.0.7 peer-group mbgp neighbor 10.0.0.8 peer-group mbgp neighbor 10.0.0.9 peer-group mbgp neighbor 10.0.0.10 peer-group mbgp no auto-summary ! address-family vpnv4 neighbor mbgp send-community both neighbor 10.0.0.1 activate neighbor 10.0.0.2 activate neighbor 10.0.0.3 activate neighbor 10.0.0.5 activate neighbor 10.0.0.6 activate neighbor 10.0.0.7 activate neighbor 10.0.0.8 activate neighbor 10.0.0.9 activate neighbor 10.0.0.10 activate exit-address-family ! address-family ipv4 vrf vrfNONAME redistribute connected redistribute static no auto-summary no synchronization exit-address-family ! address-family ipv4 vrf vrfNONAME redistribute connected redistribute static redistribute ospf 106 match internal external 1 external 2 no auto-summary no synchronization network 0.0.0.0 exit-address-family ! address-family ipv4 vrf vrfNONAME redistribute connected redistribute static metric 1 no auto-summary no synchronization exit-address-family ! address-family ipv4 vrf vrfNONAME no auto-summary no synchronization exit-address-family ! address-family ipv4 vrf vrfNONAME redistribute connected redistribute static redistribute ospf 104 no auto-summary no synchronization exit-address-family ! address-family ipv4 vrf vrfNONAME redistribute connected redistribute static redistribute ospf 103 match internal external 1 external 2 no auto-summary no synchronization network 0.0.0.0 exit-address-family ! address-family ipv4 vrf vrfNONAME no auto-summary no synchronization exit-address-family ! address-family ipv4 vrf vrfNONAME redistribute connected redistribute ospf 101 match internal external 2 no auto-summary no synchronization exit-address-family ! address-family ipv4 vrf vrfNONAME redistribute connected redistribute static redistribute ospf 105 match internal external 1 external 2 no auto-summary no synchronization exit-address-family ! address-family ipv4 vrf vrfNONAME no auto-summary no synchronization exit-address-family ! address-family ipv4 vrf vrfNONAME redistribute connected redistribute static metric 1 redistribute ospf 107 match internal external 1 external 2 no auto-summary no synchronization exit-address-family !
7200-01sf#show ip route sum IP routing table name is Default-IP-Routing-Table(0) Route Source Networks Subnets Overhead Memory (bytes) connected 0 97 6492 14744 static 1 0 64 152 ospf 100 3 184 15232 28424 Intra-area: 104 Inter-area: 47 External-1: 0 External-2: 36 NSSA External-1: 0 NSSA External-2: 0 ospf 101 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 102 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 103 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 bgp 65520 0 0 0 0 External: 0 Internal: 0 Local: 0 ospf 104 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 105 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 106 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 107 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 internal 3 3516 Total 7 281 21788 46836 7200-01sf#sho ip route vrf vrfData sum IP routing table name is vrfData(4) Route Source Networks Subnets Overhead Memory (bytes) connected 0 95 6216 14440 static 1 3 256 608 ospf 100 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 101 0 262 17856 39824 Intra-area: 77 Inter-area: 102 External-1: 0 External-2: 83 NSSA External-1: 0 NSSA External-2: 0 ospf 102 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 103 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 bgp 65520 0 415 26560 63080 External: 0 Internal: 415 Local: 0 ospf 104 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 105 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 106 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 ospf 107 0 0 0 0 Intra-area: 0 Inter-area: 0 External-1: 0 External-2: 0 NSSA External-1: 0 NSSA External-2: 0 internal 12 14064 Total 13 775 50888 132016
