HC Counter Timer ??
Jun 03, 2006 1 Replies
Merv
I believe HC counters are high-capacity counters (i.e. 64 bits). Not sure what the timer process does
Does anyone know what this process does (HC Counter Timer)? It was using 40% of memory on a 3850
Cisco IOS Software, 3800 Software (C3825-IPBASE-M), Version 12.3(11)T2, RELEASE SOFTWARE (fc1) Technical Support:
(c) 1986-2004 by Cisco Systems, Inc. Compiled Fri 29-Oct-04 07:35 by cmong
ROM: System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1)
keyon-gj-gw uptime is 23 hours, 47 minutes System returned to ROM by reload at 08:26:11 PST Fri Jun 2 2006 System image file is "flash:c3825-ipbase-mz.123-11.T2.bin"
Cisco 3825 (revision 1.0) with 232448K/29696K bytes of memory. Processor board ID FHK0905F3L3
2 Gigabit Ethernet interfaces
1 Serial interface
1 Subrate T3/E3 port DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62592K bytes of ATA System CompactFlash (Read/Write)
Configuration register is 0x2102
CPU utilization for five seconds: 1%/1%; one minute: 1%; five minutes:
1% PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 22 131728 21381 6160 0.31% 0.31% 0.31% 0 HC Counter Timer
