My 836 has 32MB base memory and a 16MB card. Can I replace this card by a
32MB model? The new 836 has 64MB of base memory and a maximum of 80MB (also the newer IOS versions need 64MB of DRAM)
Regards, Carsten
You can try a 32MB module from a 1700 series router. Perhaps it works. I was able to upgrade SOHO9x routers to 48MB with a MEM830-16D module. Even if they are not upgradeable ;-) Hard to believe, that the developers don't respect the memory limits of a given target platform.…
Read the full replyMy 836 has 32MB base memory and a 16MB card. Can I replace this card by a
Regards, Carsten
Hard to believe, that the developers don't respect the memory limits of a given target platform. Now that less that 0.1 percent of all C83x/SOHO9x router in the field are the new 64MB models, you can now order for a few weeks...
Uli Link wrote in news:425f7e4b$0$1494$ snipped-for-privacy@newsread4.arcor-online.net:
Unfortunately the reality :-(
c836-xxxxxxx-14.T1.bin , DRAM >64MB , FLASH >12MB , 14-APR-2005
Hi Carsten,
You may wish to investigate Cisco Router Memory Tables:
Brad Reese BradReese.Com Cisco Repair Worldwide Toll Free: 877-549-2680 International: 828-277-7272 Website:
"BradReeseCom" wrote in news:1113579484.666101.287860 @f14g2000cwb.googlegroups.com:
Thank you for your information! Unfortunately the same problem: max. memory only 48MB but the newewst IOS versions need 64MB... :-(
The old versions will not support latest images. You'll need physically new unit, with P/N ending with -64MB to run latest releases. It's hardware thing, old units simply can't be upgraded.
Cisco posted an bulletin on CCO about that upgrade:
Perfect! :-( Last month I bought a new service contract for software updates, which I can't use...
There is nothing mentioned about the older Routers with 32MB onboard. I don't know a physical reason, why the C83x routers won't accept a 32MB module instead of the 16MB module.
There are also new 12.3(11)T and 12.3(8)T rebuilds ;-)
It does actually talk about the old models under the "New Product Part Numbers" : "The old part numbers cannot be upgraded for additional DRAM and will be phased out."
Doesn't look good..
Hmmmm. I've bought an old 827H. It's now running on 12.3(11)T3. It has 32Mb!!!!
Here's the IOS report
----------------------------------------------------------------------------- User Access Verification
Password: CISCO827>ena Password: CISCO827#sh ver Cisco IOS Software, C820 Software (C820-K9OSY6-M), Version 12.3(11)T3, RELEASE S OFTWARE (fc4) Technical Support:
ROM: System Bootstrap, Version 12.2(4r)XM2, RELEASE SOFTWARE (fc1)
CISCO827 uptime is 1 day, 18 hours, 17 minutes System returned to ROM by power-on System image file is "flash:c820-k9osy6-mz.123-11.T3.bin"
This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco C827H (MPC855T) processor (revision 0x501) with 31744K/1024K bytes of memo ry. Processor board ID FOC073313D6 (3066090257), with hardware revision 0000 CPU rev number 5
1 Ethernet interface 1 ATM interface 128K bytes of NVRAM. 8192K bytes of processor board System flash (Read/Write) 2048K bytes of processor board Web flash (Read/Write)Configuration register is 0x2102
