Memory upgrade for PIX 515E
Nov 12, 2007 5 Replies
Jump to replies (5)
Memory upgrade for PIX 515E open original image
Can a PIX 515E with the following configuration upgraded to 128 MB of RAM?
Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz Flash E28F128J3 @ 0xfff00000, 16MB BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Licensed features for this platform: Maximum Physical Interfaces : 3 Maximum VLANs : 10 Inside Hosts : Unlimited Failover : Disabled VPN-DES : Enabled VPN-3DES-AES : Enabled Cut-through Proxy : Enabled Guards : Enabled URL Filtering : Enabled Security Contexts : 0 GTP/GPRS : Disabled VPN Peers : Unlimited
This platform has a Restricted (R) license.
Thank you for your time.
| Can a PIX 515E with the following configuration upgraded to 128 MB of | RAM? | | Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz | Flash E28F128J3 @ 0xfff00000, 16MB | BIOS Flash AM29F400B @ 0xfffd8000, 32KB | | Licensed features for this platform: | Maximum Physical Interfaces : 3 | Maximum VLANs : 10 | Inside Hosts : Unlimited | Failover : Disabled | VPN-DES : Enabled | VPN-3DES-AES : Enabled | Cut-through Proxy : Enabled | Guards : Enabled | URL Filtering : Enabled | Security Contexts : 0 | GTP/GPRS : Disabled | VPN Peers : Unlimited | | This platform has a Restricted (R) license. | | Thank you for your time.
To clarify my question: I read here:
in order to be able to upgrade the memory of a PIX-515E from 64MB to 128MB it has to have either Unrestricted or Failover license. Is this so or have I misunderstood something?
Regards...
Why not? here is output from one of my "pixes"
pixfirewall# sh ver
Cisco PIX Security Appliance Software Version 8.0(3)
Compiled on Tue 06-Nov-07 19:50 by builders System image file is "flash:/pix803.bin" Config file at boot was "startup-config"
pixfirewall up 36 secs
Hardware: PIX-515, 256 MB RAM, CPU Pentium 200 MHz Flash i28F640J5 @ 0x300, 16MB BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: Ext: Ethernet0 : address is 0004.9ad0.d7cc, irq 11 1: Ext: Ethernet1 : address is 0004.9ad0.d7cd, irq 10 2: Ext: Ethernet2 : address is 0090.2775.c310, irq 9
pixfirewall# sh mem Free memory: 154794120 bytes (58%) Used memory: 113641336 bytes (42%)
------------- ---------------- Total memory: 268435456 bytes (100%) pixfirewall#
thanks Roman Nakhmanson
In the message snipped-for-privacy@gmail.com wrote:
| On Nov 12, 10:02 am, Morph wrote: | > Can a PIX 515E with the following configuration upgraded to 128 MB of | > RAM? | >
| > Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz | > Flash E28F128J3 @ 0xfff00000, 16MB | > BIOS Flash AM29F400B @ 0xfffd8000, 32KB | >
| > Licensed features for this platform: | > Maximum Physical Interfaces : 3 | > Maximum VLANs : 10 | > Inside Hosts : Unlimited | > Failover : Disabled | > VPN-DES : Enabled | > VPN-3DES-AES : Enabled | > Cut-through Proxy : Enabled | > Guards : Enabled | > URL Filtering : Enabled | > Security Contexts : 0 | > GTP/GPRS : Disabled | > VPN Peers : Unlimited | >
| > This platform has a Restricted (R) license. | >
| > Thank you for your time. | | Why not? | here is output from one of my "pixes" | | pixfirewall# sh ver | | Cisco PIX Security Appliance Software Version 8.0(3) | | Compiled on Tue 06-Nov-07 19:50 by builders | System image file is "flash:/pix803.bin" | Config file at boot was "startup-config" | | pixfirewall up 36 secs | | Hardware: PIX-515, 256 MB RAM, CPU Pentium 200 MHz | Flash i28F640J5 @ 0x300, 16MB | BIOS Flash AT29C257 @ 0xfffd8000, 32KB | | 0: Ext: Ethernet0 : address is 0004.9ad0.d7cc, irq 11 | 1: Ext: Ethernet1 : address is 0004.9ad0.d7cd, irq 10 | 2: Ext: Ethernet2 : address is 0090.2775.c310, irq 9 | | Licensed features for this platform: | Maximum Physical Interfaces : 3 | Maximum VLANs : 10 | Inside Hosts : Unlimited | Failover : Disabled | VPN-DES : Enabled | VPN-3DES-AES : Enabled | Cut-through Proxy : Enabled | Guards : Enabled | URL Filtering : Enabled | Security Contexts : 0 | GTP/GPRS : Disabled | VPN Peers : Unlimited | | This platform has a Restricted (R) license. | | | | pixfirewall# sh mem | Free memory: 154794120 bytes (58%) | Used memory: 113641336 bytes (42%) | ------------- ---------------- | Total memory: 268435456 bytes (100%) | pixfirewall# | | thanks | Roman Nakhmanson
Thank you! Did you just remove the installed memory and install a regular SD RAM yourself? Because there is no option to order 256 MB memory through cisco.
Regards.
yes
of course not. 8-)
PIX 515 (or 515E in your case ) is the (more or less) Intel pentium based PC. It supports up to 256M of RAM.
Memory module has to have low density chips. In other words - you need two PC-133 non-ECC 8-chip 128MB modules
Cheers Roman Nakhmanson
In the message
| On Nov 15, 4:05 am, Morph wrote: | > In the message | >
| > snipped-for-privacy@gmail.com wrote: | >
| > | On Nov 12, 10:02 am, Morph wrote: | > | > Can a PIX 515E with the following configuration upgraded to 128 MB of | > | > RAM? | > | >
| > | > Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz | > | > Flash E28F128J3 @ 0xfff00000, 16MB | > | > BIOS Flash AM29F400B @ 0xfffd8000, 32KB | > | >
| > | > Licensed features for this platform: | > | > Maximum Physical Interfaces : 3 | > | > Maximum VLANs : 10 | > | > Inside Hosts : Unlimited | > | > Failover : Disabled | > | > VPN-DES : Enabled | > | > VPN-3DES-AES : Enabled | > | > Cut-through Proxy : Enabled | > | > Guards : Enabled | > | > URL Filtering : Enabled | > | > Security Contexts : 0 | > | > GTP/GPRS : Disabled | > | > VPN Peers : Unlimited | > | >
| > | > This platform has a Restricted (R) license. | > | >
| > | > Thank you for your time. | > | | > | Why not? | > | here is output from one of my "pixes" | > | | > | pixfirewall# sh ver | > | | > | Cisco PIX Security Appliance Software Version 8.0(3) | > | | > | Compiled on Tue 06-Nov-07 19:50 by builders | > | System image file is "flash:/pix803.bin" | > | Config file at boot was "startup-config" | > | | > | pixfirewall up 36 secs | > | | > | Hardware: PIX-515, 256 MB RAM, CPU Pentium 200 MHz | > | Flash i28F640J5 @ 0x300, 16MB | > | BIOS Flash AT29C257 @ 0xfffd8000, 32KB | > | | > | 0: Ext: Ethernet0 : address is 0004.9ad0.d7cc, irq 11 | > | 1: Ext: Ethernet1 : address is 0004.9ad0.d7cd, irq 10 | > | 2: Ext: Ethernet2 : address is 0090.2775.c310, irq 9 | > | | > | Licensed features for this platform: | > | Maximum Physical Interfaces : 3 | > | Maximum VLANs : 10 | > | Inside Hosts : Unlimited | > | Failover : Disabled | > | VPN-DES : Enabled | > | VPN-3DES-AES : Enabled | > | Cut-through Proxy : Enabled | > | Guards : Enabled | > | URL Filtering : Enabled | > | Security Contexts : 0 | > | GTP/GPRS : Disabled | > | VPN Peers : Unlimited | > | | > | This platform has a Restricted (R) license. | > | | > | | > | | > | pixfirewall# sh mem | > | Free memory: 154794120 bytes (58%) | > | Used memory: 113641336 bytes (42%) | > | ------------- ---------------- | > | Total memory: 268435456 bytes (100%) | > | pixfirewall# | > | | > | thanks | > | Roman Nakhmanson | >
| > Thank you! | > Did you just remove the installed memory and install a regular SD RAM | > yourself? Because there is no option to order 256 MB memory through | > cisco. | >
| > Regards. | | | >Did you just remove the installed memory and install a regular SD RAM yourself? | | yes | | > Because there is no option to order 256 MB memory through cisco | | of course not. 8-) | | PIX 515 (or 515E in your case ) is the (more or less) Intel pentium | based PC. It supports up to 256M of RAM. | | Memory module has to have low density chips. In other words - you need | two PC-133 non-ECC 8-chip 128MB modules
Thank you!
