3825 or 2800 series ? Any advice..?
May 08, 2006 5 Replies
Walter Roberson
What are your in-house routing requirements? What are your security requirements? For example, will you be needing to create a DMZ? Will you be wanting VPN access from home or travelling users? Will you be using multiple subnets locally and wanting the device to route between…
3825 or 2800 series ? Any advice..? open original image
Hello Pros,
These days I have project for connecting a main office to several branch offices. Max network bandwith usage will be 2Mbit. In the main office I have 25 users and in the branch offices (2 offices at he moment , one in the city , one in an other city) 4 or 5 users max. I asked my local Cisco provider for their suggestion and they told me
3825 will be fine. By the way I am thinking to use G.SHDSL for connection between the offices using WIC-1SHDSL -V3 interface cards.
What will be your suggestion on that? I know that 2821 and 2851 both have 4 HWIC that will be sufficent for 4 G.SHDSL lines for the offices.
Here the list price fo 2811 is $2495 and they asked $9500 for 3825.. There is huge price gap with them. Well any thoughts will be great..Price performance, experiences..etc.
Best Regards, Ras
What are your in-house routing requirements? What are your security requirements? For example, will you be needing to create a DMZ? Will you be wanting VPN access from home or travelling users? Will you be using multiple subnets locally and wanting the device to route between them?
Is the implication that you might be wanting to go up to 4 external offices? You say that, "Max network bandwith usage will be
2Mbit", but does that include after the expansion to 4 offices?
What is the expected lifetime of the devices? Around here, it is getting to the point where a commercial DSL line as slow as 2 Mb/s has to be special ordered, so you should plan for bandwidth inflation over the device lifetime.
2811: 120,000 pps (@64 bytes), 61.44 Mbps 3825: 350,000 pps (@64 bytes), 179.20 Mbps
Thus neither of them should have any difficulty at all in keeping up with 2 Mb/s, or even 4 x 2 Mb/s.
However, if you start using the routing capabilities in-house, expecting to route 100 Mb/s to 100 Mb/s, then the 2811 can only do about 30% of full-duplex at those rates, whilst the 3825 would in theory be able to do 90% of full duplex at those rates.
Hey Walter, Thank you for your reply. By saying 2Mbit I meant the connection to each branch office.
A - 2mbit -> B A - 2mbit -> C
etc.
Actually Yes, I am thinking to use VPN for client access and DMZ etc.
I would advise you to go for the 2800-series. The 3800's are overkill for your scenario. The 2800's are easily capable of handling the 4 DSL circuits and even come with hardware based VPN encryption on-board so you don't need to worry about the encryption load. About the remote offices; I'd suggest you to have a look at the 850 or 870 series routers. They offer great performance and functionality for such small branches. (don't know if they're G.SHDSL capable though).
If you'd need internal routing (as walter is mentioning), consider adding a layer-3 switch, which is cheaper and faster.
Erik
and if you do run out of connections/ capacity, you can add another router or upgrade then - you could move interfaces between boxes since net modules and WICs are supported on 28xx / 38xx
routers like most computer gear follow "Moores law" and get cheaper / faster with every new model - so it doesnt make much sense to buy lots of spare potential capacity unless you are likely to need it.
when the 28xxs came out, Cisco tried to characterise each model as "enough" capacity to handle a set of circuits with some of the more CPU and prossor intensive functions turned on
AFAIR 2811 is supposed to handle 2 * 2 Mbps, full duplex, worst case packet sizes, with VPN encryption, QoS, Voip, NAT and intrusion inspection all at thesame time - in practice this means a lot of spare capacity for the config you are discussing.
"routers like most computer gear follow "Moores law" and get cheaper / faster with every new model - so it doesnt make much sense to buy lots of spare potential capacity unless you are likely to need it."
You are right on the point. There is thin line between, investing in the "actual" and "potential". Sometimes making the correct "cost effective" decision is a bit trivial.
But I think I will go with 28xx and moving the IC's to a more advanced model over the time will be OK for me.
