2 ISPs and 1 2620
Sep 19, 2006 2 Replies
Hello My ISP is in transition of changing its ISP
My question is can i have 2 routers on 1 router?
for example (do not care about IP addressess - some not real) Current status (all IP public): Default Gateway 40.40.66.1 WAN: 40.40.46.239 LAN:40.40.56.112/28
in near future they will give me new IP addressess for example Default Gateway 50.50.66.1 WAN: 50.50.46.239 LAN:50.50.56.112/28
Can I setup router to route 1 network and anpther how can i do this
I have 1 isco 2620 and 2 x FE interface
Will it work?
int FE0/0 no ip address int FE0/0.1 ip address 40.40.46.239 mmm.mmm.mmm.mmm int FE0/0.2 ip address 50.50.56.239 xxx.xxx.xxx.xxx int FE1/0 no ip address int FE1/0.1 ip address 40.40.56.112 mmm.mmm.mmm.mmm int FE1/0.2 ip address 50.50.56.112 xxx.xxx.xxx.xxx
and than what should be the routing entry?
ip route 40.40.56.112 40.40.66.1 ip route 50.50.56.112 50.50.66.1
There are ni WIC card This connection is Fa connection RJ45
------RJ45-Fa0/0--2620-Fa1/0--RJ45---Firewall-----
