Source and destination NAT
Jun 26, 2007 4 Replies
Jump to replies (4)
I have a 2621 router with FE0 attached to the Internet and FE1 attached to the LAN.
2621 FE0 X.X.X.1/29 (part of public IP block, 'outside' NAT interface) FE1 a.a.a.1/24 (private, 'inside' NAT interface)
I have two goals here, both of which I can do, I just want a better way to do them.
The first goal is to simply "port forward" public IP X.X.X.2 to LAN IP a.a.a.2, which is simple enough with destination NAT:
[source ][dest X.X.X.2] DestNAT-> [source ][dest a.a.a.2]
The second goal is where I started making stuff up. Because in addition to being destination NATed to "b.b.b.6", public IP X.X.X.3 must also be source NATed to appear to have originated on the b.b.b.0 subnet. So for lack of a better idea, I did this:
First I destination NAT it to the appropriate LAN address:
[source ][dest X.X.X.3] DestNAT-> [source ][dest b.b.b.6]
My hack solution is to then route it to a second 2621 router:
ip route b.b.b.0/24 -> a.a.a.5
And the second 2621 looks like this:
2621 #2 FE0 a.a.a.5/24 (inside) FE1 b.b.b.1/24 (outside)
And using a traditional internet connection sharing routine, I nat the source:
[source ][dest b.b.b.6] SourceNAT -> [source b.b.b.1][dest b.b.b.6] ip route 0.0.0.0/0 -> a.a.a.1
So, from the perspective of the server at b.b.b.6, all the requests it's getting appear to be coming from LAN source b.b.b.1 (rather than WAN source ). Which accomplishes "the goal".
This works, but my question is, is it possible to do this with 1 router? Could I put, say, an NM-4E module into a single 2621 and route packets to "myself" so that I can destination NAT them as well as source NAT them?
I have to reproduce this at another location with the same goals, but at the other location there's only one 2621 router to play with.
Google for "nat on a stick". You don't need another module, you use a loopback interface for this.
Thanks for the hint.
I've got it "almost" working, I think, in my 1720 sandbox, but I'm not seeing what I'm missing... the 1720 has 2 interfaces and a loopback, like this:
WIC-1ENET (e0) outside NAT (faces WAN) FastEther (f0) inside NAT (faces LAN) Loopback (l0) inside
A packet shows up on e0 from the InternetGuy for my Public IP X.X.X.2
00:05:31: NAT: o: tcp ([InternetGuy], 3157) -> (X.X.X.2, 80) [18160]
An ip nat inside dest rule is in place to turn X.X.X.2 into 172.16.2.200, which happens:
00:05:31: NAT: s=[InternetGuy], d=X.X.X.2->172.16.2.200 [18160]
Now before the device at 172.16.2.200 receives this packet I need to make the source change from [InternetGuy] to 172.16.2.12. I have a policy route (on e0) to loopback when this is the case, which happens:
00:05:31: IP: s=[InternetGuy] (Ethernet0), d=172.16.2.200, len 48, policy match 00:05:31: IP: route map DoubleNAT, item 10, permit 00:05:31: IP: s=[InternetGuy] (Ethernet0), d=172.16.2.200 (Loopback0), len 48, policy routed 00:05:31: IP: Ethernet0 to Loopback0 172.16.2.200
An ip nat inside source rule is in palce to turn [InternetGuy] into
172.16.2.12, which does not happen. Now the packet is apparently routed to 172.16.2.200, because the next debug line appears to be my device (web server) responding:
00:05:31: NAT: i: tcp (172.16.2.200, 80) -> ([InternetGuy], 3157) [51052]
00:05:31: NAT: s=172.16.2.200->X.X.X.2, d=([InternetGuy] [51052]
Without the second NAT occuring, my loopback is pointless overhead so far.
This is what I thought might happen (what I want to happen):
00:05:31: NAT: o: tcp ([InternetGuy], 3157) -> (X.X.X.2, 80) [18160] 00:05:31: NAT: s=[InternetGuy], d=X.X.X.2->172.16.2.200 [18160] 00:05:31: IP: s=[InternetGuy] (Ethernet0), d=172.16.2.200, len 48, policy match 00:05:31: IP: route map DoubleNAT, item 10, permit 00:05:31: IP: s=[InternetGuy] (Ethernet0), d=172.16.2.200 (Loopback0), len 48, policy routed 00:05:31: IP: Ethernet0 to Loopback0 172.16.2.200 00:05:31: NAT: i: tcp ([InternetGuy], 3157) -> (172.16.2.200, 80) 00:05:31: NAT: s=[InternetGuy]->172.16.2.12, d=172.16.2.200
The last 2 lines never happen, even though there is an inside source NAT rule in place that fits the criteria of what gets sent to loopback.
Have a look here
for an example and explanations. ( that's Document ID: 6505 in case you have a problem getting through on this link)
Luck, Frans
I had to implement nat on a stick, with multiple Loopback interfaces & policy routes, etc. similar to the examples in document 6505. I had to fill some gaps in my NAT knowledge to really get it, but I got it working eventually. Thanks for the help guys.
