1811W - PC's can no longer see eachother AT ALL!!! (HELP!)
Mar 15, 2006 14 Replies
Jump to replies (14)
Hi all - I have several/many pc's connected to an 1811W. Since I upgraded to the 1811W - no pc can see any other. No file sharing, no printer sharing, computers cannot even ping each other - yet all computers get IP address's from the router and can access the internet perfectly.
I have done EVERYTHING you can with these XP Pro machines and I am left thinking its something I need to do in the router so that all of the computers connected to it can see each other and share stuff out (which is integral to my own business). I have nothing but the basics setup on the router and haven't really done much in their to tool around. I am also not a Cisco expert (been years since I was in a Cisco 'class') - so if someone could just tell me what it is I need to do, that would great. I am not looking for anything extreme here - i just want any PC connected to the router to be able to see any other PC connected to the router.
I have several devices connected through Ethernet and several wireless devices connected as well.
(Sorry for typos)
Verify that PSPF (Public Secure Port Forwarding) is not configured on the radio interface.
This feature prevents wireless clients from communicating with each other.
sh run interface dot11radio
here is the configuration file output when I log in - perhaps this will answer any questions (perhaps not, more information from me follows this):
OutputCommand base-URL was: /level/15/exec/- Complete URL was: /level/15/exec/-/show/running-config/CR Command was: show running-config-------------------------------------------------------------------------------- Building configuration...
Current configuration : 6681 bytes ! version 12.4 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname neogenesisconsultingHOST ! boot-start-marker boot-end-marker ! security authentication failure rate 3 log security passwords min-length 6 logging buffered 51200 debugging logging console critical enable secret 5 $1$W.YL$cVtwrjeXt9YYlRHufyBHk/ ! no aaa new-model ! resource policy ! clock timezone PCTime -5 clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout
180 ip subnet-zero no ip source-route ! ! ip cef no ip dhcp use vrf connected ip dhcp excluded-address 10.10.10.1 ! ip dhcp pool sdm-pool1 import all network 10.10.10.0 255.255.255.0 default-router 10.10.10.1 ! ! ip tcp synwait-time 10 no ip bootp server no ip domain lookup ip ssh time-out 60 ip ssh authentication-retries 2 ip inspect name DEFAULT100 cuseeme ip inspect name DEFAULT100 ftp ip inspect name DEFAULT100 h323 ip inspect name DEFAULT100 icmp ip inspect name DEFAULT100 netshow ip inspect name DEFAULT100 rcmd ip inspect name DEFAULT100 realaudio ip inspect name DEFAULT100 rtsp ip inspect name DEFAULT100 esmtp ip inspect name DEFAULT100 sqlnet ip inspect name DEFAULT100 streamworks ip inspect name DEFAULT100 tftp ip inspect name DEFAULT100 tcp ip inspect name DEFAULT100 udp ip inspect name DEFAULT100 vdolive no ip ips deny-action ips-interface ! ! crypto pki trustpoint TP-self-signed-2345652485 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-2345652485 revocation-check none rsakeypair TP-self-signed-2345652485 ! ! crypto pki certificate chain TP-self-signed-2345652485 certificate self-signed 01 30820251 308201BA A0030201 02020101 300D0609 2A864886 F70D0101 04050030 31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274 69666963 6174652D 32333435 36353234 3835301E 170D3036 30333135 30353139 33365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649 4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33343536 35323438 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100C083 9EFC9CBC 94676E66 6ED39350 0DEED0D6 F340B1E7 7F111DD7 5684A031 1C89116E B519165C 62C2F30D 10149297 4371A9E6 33DF49BB E3D30622 7ED84D7A 06AC3A30 CD70BB39 7AB85587 711F90B5 B031DBDE A37F7401 4408DB25 9A96CC36 F3DF5F54 9BBD83DC 4E62853D ACF46ECC FC7C4F5C E297992F 7CF24AE2 3D30F30A 504D0203 010001A3 79307730 0F060355 1D130101 FF040530 030101FF 30240603 551D1104 1D301B82 196E656F 67656E65 73697363 6F6E7375 6C74696E 67484F53 542E301F 0603551D 23041830 16801405 7DB2DDBF 35D2BBA4 381AB3C8 5350091E 4005CB30 1D060355 1D0E0416 0414057D B2DDBF35 D2BBA438 1AB3C853 50091E40 05CB300D 06092A86 4886F70D 01010405 00038181 005C0D6F 5B2FF8FF F6B9252F 30709EBB 634BB310 A7C9425C 7C9468E0 2206E9D9 9A7F0F90 5089450B 6FFBDD21 7D9570F3 D8D44CAB 05DF88AD 9AF7C120 96754B51 BEA34F0F 11FABA8A 1A1CBC54 FA4713F0 5768CEB5 9D59475A C8E3BB5E 11FE8009 67D7A4DF 4475E3CA 9E6B4994 3A23DAB5 21A50A94 C79C125B 04E3EF0F FC48134A 29 quit username jameshulsmann privilege 15 secret 5 $1$WyzX$hnIcbfNvQBddGRbBE9jPz. ! ! ! bridge irb ! ! interface Dot11Radio0 no ip address ! ssid neogenesisconsulting authentication open ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 bridge-group 1 bridge-group 1 spanning-disabled ! interface Dot11Radio1 no ip address ! ssid neogenesisconsulting authentication open ! speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 station-role root bridge-group 1 bridge-group 1 spanning-disabled ! interface FastEthernet0 description $ES_WAN$$FW_OUTSIDE$ ip address dhcp client-id FastEthernet0 ip access-group 101 in no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip inspect DEFAULT100 out ip virtual-reassembly ip route-cache flow duplex auto speed auto ! interface FastEthernet1 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow shutdown duplex auto speed auto ! interface FastEthernet2 ! interface FastEthernet3 ! interface FastEthernet4 ! interface FastEthernet5 ! interface FastEthernet6 ! interface FastEthernet7 ! interface FastEthernet8 ! interface FastEthernet9 ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$FW_INSIDE$ no ip address bridge-group 1 ! interface Async1 no ip address no ip redirects no ip unreachables no ip proxy-arp ! interface BVI1 description $ES_LAN$$FW_INSIDE$ ip address 10.10.10.1 255.255.255.0 ip access-group 100 in ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 ! ip classless ! ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 5 life 86400 requests 10000 ip nat inside source list 1 interface FastEthernet0 overload ! logging trap debugging access-list 1 remark INSIDE_IF=BVI1 access-list 1 remark SDM_ACL Category=2 access-list 1 permit 10.10.10.0 0.0.0.255 access-list 100 remark auto-generated by Cisco SDM Express firewall configuration access-list 100 remark SDM_ACL Category=1 access-list 100 deny ip host 255.255.255.255 any access-list 100 deny ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip any any access-list 101 remark auto-generated by Cisco SDM Express firewall configuration access-list 101 remark SDM_ACL Category=1 access-list 101 permit udp any eq bootps any eq bootpc access-list 101 deny ip 10.10.10.0 0.0.0.255 any access-list 101 permit icmp any any echo-reply access-list 101 permit icmp any any time-exceeded access-list 101 permit icmp any any unreachable access-list 101 deny ip 10.0.0.0 0.255.255.255 any access-list 101 deny ip 172.16.0.0 0.15.255.255 any access-list 101 deny ip 192.168.0.0 0.0.255.255 any access-list 101 deny ip 127.0.0.0 0.255.255.255 any access-list 101 deny ip host 255.255.255.255 any access-list 101 deny ip any any no cdp run ! ! ! ! control-plane ! bridge 1 protocol ieee bridge 1 route ip banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!^C ! line con 0 login local transport output telnet line 1 modem InOut stopbits 1 speed 115200 flowcontrol hardware line aux 0 login local transport output telnet line vty 0 4 privilege level 15 login local transport input telnet ssh line vty 5 15 privilege level 15 login local transport input telnet ssh ! scheduler allocate 4000 1000 scheduler interval 500 end
--------------------------------------------------------------------------------command completed.
I Hope that helps ;-) Beyond that, I essentialy have factory defualts. The only thing that I really specified was that the radio connections should use the same IP pool as the wired. The WAN interface uses FastEthernet0 (that port to connect to the outside internet); the "inside" network connection (not physically, just anything that's on the 'inside' of the router) seems to be called something like "BVI1"; the internal net address range from 10.10.10.1 (the router) to
10.10.10.250-something; the host name for the router is "neogenesisconsultingHOST"; and the router gets its outside IP dynamically and is a DHCP client; there is no domain because, really, there isnt one as of yet.
I am not sure what else to tell you - let me know and THANK YOU for any help!
Well, its not just the wirelessly connected machines - no machine (wired or wireless) can even ping any other machine. Its as if the router is isolatuing each machine its connect to so that it can communicate with it and the outside world, but not anyhting on the inside. Config file is posted...
please post:
show version
sh ip int brief
sh interface
sh ip route
sh ip arp
sh ip dhcp bindings
sh bridge
sh vlan
sh ip traffic
SHOW VERSION:
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version
12.4(2)T2, RELEASE SOFTWARE (fc3) Technical Support:
(c) 1986-2005 by Cisco Systems, Inc. Compiled Tue 18-Oct-05 13:40 by ccai
ROM: System Bootstrap, Version 12.3(8r)YH5, RELEASE SOFTWARE (fc1)
neogenesisconsultingHOST uptime is 23 hours, 30 minutes System returned to ROM by power-on System image file is "flash:c181x-advipservicesk9-mz.124-2.T2.bin"
This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
If you require further assistance please contact us by sending email to snipped-for-privacy@cisco.com.
Cisco 1811W (MPC8500) processor (revision 0x300) with 118784K/12288K bytes of memory. Processor board ID FTX0947Z1WT, with hardware revision 0000
10 FastEthernet interfaces 1 Serial interface 1 terminal line 2 802.11 Radios 31360K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102
SH IP INT BRIEF:
Interface IP-Address OK? Method Status Protocol Async1 unassigned YES NVRAM down down BVI1 10.10.10.1 YES NVRAM up up Dot11Radio0 unassigned YES TFTP up up Dot11Radio1 unassigned YES TFTP up up FastEthernet0 68.194.200.56 YES DHCP up up FastEthernet1 unassigned YES NVRAM administratively down down FastEthernet2 unassigned YES unset up up FastEthernet3 unassigned YES unset up up FastEthernet4 unassigned YES unset up down FastEthernet5 unassigned YES unset up down FastEthernet6 unassigned YES unset up down FastEthernet7 unassigned YES unset up down FastEthernet8 unassigned YES unset up down FastEthernet9 unassigned YES unset up down NVI0 unassigned YES unset up up Virtual-Dot11Radio0 unassigned YES TFTP down down Virtual-Dot11Radio1 unassigned YES TFTP down down Vlan1 unassigned YES NVRAM up up
SH INTERFACE:
Async1 is down, line protocol is down Hardware is PQUICC3 Serial in async mode (TTY1) MTU 1500 bytes, BW 9 Kbit, DLY 100000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation SLIP, loopback not set DTR is pulsed for 5 seconds on reset Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 6 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions BVI1 is up, line protocol is up Hardware is BVI, address is 0014.f170.6dd0 (bia 0014.f170.6dd0) Description: $ES_LAN$$FW_INSIDE$ Internet address is 10.10.10.1/24 MTU 1500 bytes, BW 54000 Kbit, DLY 5000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:05:10, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/0 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 1000 bits/sec, 2 packets/sec 152524 packets input, 78864464 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 433013 packets output, 183043482 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out Dot11Radio0 is up, line protocol is up Hardware is 802.11G Radio, address is 0014.f170.6dd0 (bia
0014.f170.6dd0) MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:48, output 00:00:17, output hang never Last clearing of "show interface" counters never Input queue: 0/75/14215/0 (size/max/drops/flushes); Total output drops: 155 Queueing strategy: fifo Output queue: 0/30 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 21812 packets input, 3631870 bytes, 0 no buffer Received 14302 broadcasts, 0 runts, 0 giants, 1 throttles 2257 input errors, 546 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 32425 packets output, 22477192 bytes, 0 underruns 152 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Dot11Radio1 is up, line protocol is up Hardware is 802.11A Radio, address is 0014.f170.6dc0 (bia 0014.f170.6dc0) MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec, reliability 253/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:03, output 00:00:17, output hang never Last clearing of "show interface" counters never Input queue: 0/75/37/0 (size/max/drops/flushes); Total output drops: 34 Queueing strategy: fifo Output queue: 0/30 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 35352 packets input, 3076881 bytes, 0 no buffer Received 3754 broadcasts, 0 runts, 0 giants, 0 throttles 4158 input errors, 991 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 24451 packets output, 19046373 bytes, 0 underruns 11 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet0 is up, line protocol is up Hardware is PQ3_TSEC, address is 0014.6a65.c5a0 (bia 0014.6a65.c5a0) Description: $ES_WAN$$FW_OUTSIDE$ Internet address is 68.194.200.56/20 MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 3000 bits/sec, 5 packets/sec 5 minute output rate 1000 bits/sec, 3 packets/sec 1136110 packets input, 222086848 bytes Received 710277 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 426832 packets output, 99493951 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet1 is administratively down, line protocol is down Hardware is PQ3_TSEC, address is 0014.6a65.c5a1 (bia 0014.6a65.c5a1) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Unknown Speed, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet2 is up, line protocol is up Hardware is FastEthernet, address is 0014.6a65.c5a2 (bia 0014.6a65.c5a2) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 13996 packets input, 1343153 bytes, 0 no buffer Received 921 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 99875 packets output, 22468670 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet3 is up, line protocol is up Hardware is FastEthernet, address is 0014.6a65.c5a3 (bia 0014.6a65.c5a3) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 2000 bits/sec, 3 packets/sec 5 minute output rate 2000 bits/sec, 3 packets/sec 406389 packets input, 97944496 bytes, 0 no buffer Received 4838 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 429401 packets output, 133417822 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet4 is up, line protocol is down Hardware is FastEthernet, address is 0014.6a65.c5a4 (bia 0014.6a65.c5a4) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto-speed ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet5 is up, line protocol is down Hardware is FastEthernet, address is 0014.6a65.c5a5 (bia 0014.6a65.c5a5) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto-speed ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet6 is up, line protocol is down Hardware is FastEthernet, address is 0014.6a65.c5a6 (bia 0014.6a65.c5a6) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto-speed ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet7 is up, line protocol is down Hardware is FastEthernet, address is 0014.6a65.c5a7 (bia 0014.6a65.c5a7) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto-speed ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet8 is up, line protocol is down Hardware is FastEthernet, address is 0014.6a65.c5a8 (bia 0014.6a65.c5a8) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto-speed ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out FastEthernet9 is up, line protocol is down Hardware is FastEthernet, address is 0014.6a65.c5a9 (bia 0014.6a65.c5a9) MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto-speed ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out NVI0 is up, line protocol is up Hardware is NVI MTU 1514 bytes, BW 10000000 Kbit, DLY 0 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation UNKNOWN, loopback not set Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out Virtual-Dot11Radio0 is down, line protocol is down Hardware is Virtual Dot11 interface, address is 0014.f170.6dc0 (bia 0014.f170.6dc0) MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters 23:33:57 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/30 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Virtual-Dot11Radio1 is down, line protocol is down Hardware is Virtual Dot11 interface, address is 0014.f170.6dd0 (bia 0014.f170.6dd0) MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output never, output hang never Last clearing of "show interface" counters 23:33:57 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/30 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 input packets with dribble condition detected 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Vlan1 is up, line protocol is up Hardware is EtherSVI, address is 0014.6a65.c5a0 (bia 0014.6a65.c5a0) Description: $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$FW_INSIDE$ MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 1000 bits/sec, 3 packets/sec 5 minute output rate 2000 bits/sec, 3 packets/sec 400486 packets input, 96213013 bytes, 0 no buffer Received 5889 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 456132 packets output, 148641593 bytes, 0 underruns 0 output errors, 1 interface resets 0 output buffer failures, 0 output buffers swapped out
SH IP ROUTE:
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2 i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route
Gateway of last resort is 68.194.192.1 to network 0.0.0.0
68.0.0.0/20 is subnetted, 1 subnets C 68.194.192.0 is directly connected, FastEthernet0 10.0.0.0/24 is subnetted, 1 subnets C 10.10.10.0 is directly connected, BVI1 167.206.0.0/32 is subnetted, 1 subnets S 167.206.3.168 [254/0] via 68.194.192.1, FastEthernet0 S* 0.0.0.0/0 [254/0] via 68.194.192.1
SH IP ARP:
Protocol Address Age (min) Hardware Addr Type Interface Internet 10.10.10.8 4 0007.e93e.24e8 ARPA BVI1 Internet 10.10.10.2 1 000f.1f54.9f02 ARPA BVI1 Internet 10.10.10.3 1 0005.4e41.7af7 ARPA BVI1 Internet 10.10.10.1 - 0014.f170.6dd0 ARPA BVI1 Internet 10.10.10.6 3 0090.f53a.3ea9 ARPA BVI1 Internet 10.10.10.4 2 0013.ce9c.2020 ARPA BVI1 Internet 68.194.192.1 0 0005.00e5.466e ARPA FastEthernet0 Internet 68.194.200.56 - 0014.6a65.c5a0 ARPA FastEthernet0
SH IP DHCP BINDING:
Bindings from all pools not associated with VRF: IP address Client-ID/ Lease expiration Type Hardware address/ User name
10.10.10.2 0100.0f1f.549f.02 Mar 16 2006 12:20 PM Automatic 10.10.10.3 0100.054e.417a.f7 Mar 16 2006 12:20 PM Automatic 10.10.10.4 0100.13ce.9c20.20 Mar 16 2006 11:29 PM Automatic 10.10.10.6 0100.90f5.3a3e.a9 Mar 16 2006 05:22 PM Automatic 10.10.10.7 0100.125a.3e18.da Mar 16 2006 02:10 PM Automatic 10.10.10.8 0100.07e9.3e24.e8 Mar 16 2006 02:52 PM Automatic
SH BRIDGE:
Total of 300 station blocks, 296 free Codes: P - permanent, S - self
Bridge Group 1:
Address Action Interface Age RX count TX count
0005.4e41.7af7 forward Dot11Radio1 0 11269 2746 0090.f53a.3ea9 forward Vlan1 1 100274 85970 000f.1f54.9f02 forward Vlan1 0 11956 30373 0007.e93e.24e8 forward Vlan1 0 272736 272294
SH VLANS:
No Virtual LANs configured.
SH IP TRAFFIC:
IP statistics: Rcvd: 1195379 total, 28724 local destination 0 format errors, 0 checksum errors, 54 bad hop count 0 unknown protocol, 64 not a gateway 0 security failures, 0 bad options, 23 with options Opts: 0 end, 0 nop, 0 basic security, 0 loose source route 0 timestamp, 0 extended security, 0 record route 0 stream ID, 0 strict source route, 23 alert, 0 cipso, 0 ump 0 other Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble 0 fragmented, 0 fragments, 0 couldn't fragment Bcast: 22365 received, 6 sent Mcast: 0 received, 0 sent Sent: 8927 generated, 846677 forwarded Drop: 12 encapsulation failed, 0 unresolved, 0 no adjacency 0 no route, 0 unicast RPF, 0 forced drop 0 options denied Drop: 0 packets with source IP address zero Drop: 0 packets with internal loop back IP address
ICMP statistics: Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 0 unreachable 171 echo, 15 echo reply, 0 mask requests, 0 mask replies, 0 quench 0 parameter, 0 timestamp, 0 info request, 0 other 0 irdp solicitations, 0 irdp advertisements Sent: 0 redirects, 0 unreachable, 29 echo, 171 echo reply 0 mask requests, 0 mask replies, 0 quench, 0 timestamp 0 info reply, 0 time exceeded, 0 parameter problem 0 irdp solicitations, 0 irdp advertisements
BGP statistics: Rcvd: 0 total, 0 opens, 0 notifications, 0 updates 0 keepalives, 0 route-refresh, 0 unrecognized Sent: 0 total, 0 opens, 0 notifications, 0 updates 0 keepalives, 0 route-refresh
TCP statistics: Rcvd: 6139 total, 0 checksum errors, 164 no port Sent: 8532 total
IP-EIGRP statistics: Rcvd: 0 total Sent: 0 total
PIMv2 statistics: Sent/Received Total: 0/0, 0 checksum errors, 0 format errors Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0 Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0 Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0 Queue drops: 0 State-Refresh: 0/0
IGMP statistics: Sent/Received Total: 0/0, Format errors: 0/0, Checksum errors: 0/0 Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0 DVMRP: 0/0, PIM: 0/0 Queue drops: 0
UDP statistics: Rcvd: 22400 total, 0 checksum errors, 8905 no port Sent: 209 total, 0 forwarded broadcasts
OSPF statistics: Rcvd: 0 total, 0 checksum errors 0 hello, 0 database desc, 0 link state req 0 link state updates, 0 link state acks
Sent: 0 total 0 hello, 0 database desc, 0 link state req 0 link state updates, 0 link state acks
ARP statistics: Rcvd: 702063 requests, 173 replies, 0 reverse, 0 other Sent: 13 requests, 641 replies (0 proxy), 0 reverse
IT CANT REALLY BE WISE TO HAVE ALL OF THIS INFORMATION SHARED OUT OVER THE INTERNET, CAN IT? HOPEFULLY YOUR NOT A HACKER OF SOME KIND! ;-)
ANYWAY - PLEASE LET ME KNOW IF THIS HELPS YOU HELP ME - AND THANK YOU FOR YOUR TIME AND HELP!
SHOW VERSION:
SH IP INT BRIEF:
SH INTERFACE:
SH IP ROUTE:
SH IP ARP:
SH IP DHCP BINDING:
SH BRIDGE:
Bridge Group 1:
SH VLANS:
SH IP TRAFFIC:
for the PC connected to interface FA2 and Fa3, try to ping one PC from the other.
assuming these are Windows PCs, go into command mode and get the MAC address of PC using ipconfig /all look for hardware addresss. make note of it.
After pinging otehr PC, issue arp -a command to see if the PC is able to sucesfully get an ARP response from the PC that was pinged. Make sure the PCs do not have any firewall software running when you do these ping tests.
Post the PCs IP address , their MAC address and the port connected to (i.e. Fa 2 or Fa 3)
BTW does the 1811W support the command "show mac-address-table"
The result of that command is as follows (show mac...)
Destination Address Address Type VLAN Destination Port
0005.4e41.7af7 Dynamic 1 Vlan1 0007.e93e.24e8 Dynamic 1 FastEthernet3 000f.1f54.9f02 Dynamic 1 FastEthernet2 0014.6a65.c5a0 Self 1 Vlan1 0014.f170.6dd0 Dynamic 1 Vlan1 0090.f53a.3ea9 Dynamic 1 FastEthernet3
The computers cannot ping eachother at all. Just tried it again, with what you said. Ping results in 100% loss - I can only ping the router and outside computers/places (like
) - but that is no shock.
here is the information on the two computers that you requested:
Destination Address Address Type VLAN Destination Port IP
0007.e93e.24e8 Dynamic 1 FastEthernet3 10.10.10.8 (dynamic) 0090.f53a.3ea9 Dynamic 1 FastEthernet3 10.10.10.6 (dynamic)
do you NEED to know anything about any of the other currently connected machines?
DAMN! I thought there would be some simple solution LOL! I just want all the PC's on the inside (of the router) to be able to see eachother. :-(
I would suggest that you try testing the connectivity between the wired devices first.
Device A is on port FA 2 with IP address 10.10.10.2 and MAC address
000f.1f54.9f02
Device B is on port FA 3 with IP address 10.10.10.6 and MAC address
0090.f53a.3ea9
Device C is on port FA 3 with IP address 10.10.10.8 and MAC address
0007.e93e.24e8
Do you have a hub plugged into the 1822W on port FA 3 ?
Can Device A (10.10.10.2) ping Device B (10.10.10.6) ?
On Windows run "cmd" and type ping followed by the IP address
then type arp -a and see what it displays
Here is an example:
C:\\>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=1ms TTL=150 Reply from 192.168.1.1: bytes=32 time
I will try that out and let you know the results - in the mean time, here is the current setup with only a small number of the total devices here connected to the router:
The router accesses the internet through a cable modem to which it is connected via the Fast Ethernet 0 port (WAN interface). Fast Ethernet
1 (the other one that can be used for a secondard WAN interface) is connected to nothing.
Device B & C connect to the router at FA 3 (as you noted) - but here is how: FA3 goes out and connects to a linksys switch - that switch is connected to a Device C and also another linksys switch, which in turns connects to Device B and an xbox 360 which is sometimes on and sometimes off (the internet is a mix of work and home-use machines - all run XP Pro, except the 360, obivously lol).
Device A connects directly to the router at FA 2 (as you noted, but perhaps was not aware of a direct connection)
There are two laptops that connect wireless to the router through its 2 WLAN-interface antenna's.
Ok - so that is the setup as it currently is - I am hoping that once this issue is settled I can throw the rest of the devices up onto this network and get back to work as I use to know it :-)
I will now try what you said to do in the above post... Again, thank you for your help!!
FROM 10.10.10.6 (Device B):
C:\\Documents and Settings\\DEVICE-B>ping 10.10.10.8
Pinging 10.10.10.8 with 32 bytes of data:
Request timed out. Request timed out. Request timed out. Request timed out.
Ping statistics for 10.10.10.8: Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\\Documents and Settings\\DEVICE-B>arp -a
Interface: 10.10.10.6 --- 0x2 Internet Address Physical Address Type 10.10.10.1 00-14-f1-70-6d-d0 dynamic 10.10.10.8 00-07-e9-3e-24-e8 dynamic
C:\\Documents and Settings\\DEVICE-B>ping 10.10.10.2
Pinging 10.10.10.2 with 32 bytes of data:
Ping statistics for 10.10.10.2: Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Interface: 10.10.10.6 --- 0x2 Internet Address Physical Address Type 10.10.10.2 00-0f-1f-54-9f-02 dynamic 10.10.10.8 00-07-e9-3e-24-e8 dynamic
C:\\Documents and Settings\\DEVICE-B>ping 10.10.10.1
Pinging 10.10.10.1 with 32 bytes of data:
Reply from 10.10.10.1: bytes=32 time=1ms TTL=255 Reply from 10.10.10.1: bytes=32 timearp -a
Interface: 10.10.10.8 --- 0x2 Internet Address Physical Address Type 10.10.10.1 00-14-f1-70-6d-d0 dynamic 10.10.10.2 00-0f-1f-54-9f-02 dynamic 10.10.10.6 00-90-f5-3a-3e-a9 dynamic
C:\\Documents and Settings\\DEVICE-C>ping 10.10.10.2
C:\\Documents and Settings\\DEVICE-C>arp -a
C:\\Documents and Settings\\DEVICE-C>ping 10.10.10.1
FROM 10.10.10.2 (DEVICE A):
C:\\Documents and Settings\\DEVICE-A>ping 10.10.10.6
Pinging 10.10.10.6 with 32 bytes of data:
Ping statistics for 10.10.10.6: Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\\Documents and Settings\\DEVICE-A>arp -a
Interface: 10.10.10.2 --- 0x2 Internet Address Physical Address Type 10.10.10.3 00-05-4e-41-7a-f7 dynamic 10.10.10.6 00-90-f5-3a-3e-a9 dynamic 10.10.10.8 00-07-e9-3e-24-e8 dynamic
C:\\Documents and Settings\\DEVICE-A>ping 10.10.10.8
C:\\Documents and Settings\\DEVICE-A>ping 10.10.10.1
  1. So all of the devices can receive ARP replies from each other as demonstrated by the results of the ping tests. This means that the devices are in fact bridged together via the 1811W. Something is blocking ping packet (ICMP packets).
2.From Device A( .2), Device B (.6) or Device C (.8), can you ping
10.10.10.3 ?
  1. Can you install Ethereal on one of the PC say Device A since it is directly connected to the 1811W. Ethereal is a packet capture program. Enable capture and ping device A from B or C. Look at the Etherreal packet capture to see if you receive an ICMP request packet (ping) from either of those devices.
to download Ethereal go to
Please post outcomes
