1600 missing commands !
Apr 07, 2005 4 Replies
Jump to replies (4)
I have a 1600 and a 2500. They work; I can ping each other via a serial cable (back to back dte/dce) I can set up routing on the 2500, but I cant (at the risk of seeming silly) find a whole set of commands on the 1600. for example :
1600(boot)(config)#ip route ^ % Invalid input detected at '^' marker.
Likewise "router rip" and "network" just don't seem to be there....
Current configuration: ! version 11.1 service udp-small-servers service tcp-small-servers ! hostname 1600 ! aaa new-model aaa authentication login vyt_m enable enable secret 5 $1$xFU8$DgDuZDb/PU.3alP4S1Gao1 enable password ah ! ! interface Ethernet0 ip address 192.168.0.44 255.255.255.0 no ip route-cache ! interface Serial0 ip address 1.1.1.2 255.255.255.0 ! tacacs-server host 169.254.32.117 line con 0 exec-timeout 0 0 line vty 0 exec-timeout 0 0 password ah login authentication vyt_m length 25 line vty 1 4 exec-timeout 0 0 password ah login authentication vyt_m ! end
"1600(boot)(config)#" ... means you are working with the tiny IOS and not the full IOS ip route is not provided in tiny IOS
to solve you problem do:
1600(boot)#show flash ..... output .... "filename.bin"
1600(boot)(config)#boot system flash "filename.bin"
1600(boot)(config)#config-register 0x2102 1600(boot)(config)#end 1600(boot)#reload ...(save?)-> YES, (reload)?->confim
wait a litle and all should be there now :-) btw "filename.bin" needs to be replaced with what is stored on your flash offcourse ;-)
alas:
1600(boot)#show flash %Device in REMOVED state
Picked it up on ebay to learn on ....someone kept the flash I assume. Might I ask(and thanks VERY much for your help) if I buy one on ebay , need I worry over wich model 1600 it came out of ? I've come to understand that only registered customers of cisco are allowed to download the IOS.....
Check out:
It's up to you to make sure the IOS is licensed properly...
ooosh thats bad businnes :-[ selling a router without memory, next time, i'll try to sell my tv-set without ray-tube in it, or my car without wheels.... i hope you did not payed much then anyway... you can find the required memory modules on ebay too, if you ask on persons that sell a lot of cisco stuff on ebay if they have such flash for ya, they will sell it with a smile. about the IOS is available at cisco if you take some contract (is very low priced) sorry i dont have any link to help you futher on that one
