According to Tom Lammle this new "password feature" of not allowing you to set the "login" command before a password is set on a line started with newer IOSes (12.2 or higher) and is not in all of their IOSes. Hope this helps clarify
That does explain the discrepancy. My routers do have 12.2
Thx, CK
