panel mounted RJ45 socket?
Aug 09, 2005 2 Replies
I'm trying to source a panel (2.5mm thick) mounted RJ45 ethernet socket, ideally a back to back socket, but I would use a socket to cable. (In fact the PERFECT thing would be a panel mounted socket with about
20-30cm of cable and a plug)
All I can seem to find is large weatherproof panel mounted things. I need the max panel usage in shortest direction to be of the order of
15-17mm.
Can anyone point me to a source.
Thanks.
Google on RJ45 bulkhead.
Ortronics makes these, I think Black Box as well.
