SB4200--what level of compliance for DOCSIS is it?
Feb 04, 2007 3 Replies
$Bill
Gregg is lazy - try Google: of the Motorola SURFboard SB4200 Cable Modem are: * DOCSIS 1.0 and 1.1 CableLabs® Certified * Utilizes the Broadcom BCM 3345 chip * New user-friendly, top-mounted stand-by button for additional end-user security * New LED added to front panel to…
SB4200--what level of compliance for DOCSIS is it? open original image
Hello! I have here a SB4200. I'd like to know if any of you know what level of DOCSIS compliance it was supposed to be at when it was made.
-- Gregg gregg dot drwho8 atsign gmail dot com "This signature has expired."
Features of the Motorola SURFboard SB4200 Cable Modem are:
  • DOCSIS 1.0 and 1.1 CableLabs® Certified * Utilizes the Broadcom BCM 3345 chip * New user-friendly, top-mounted stand-by button for additional end-user security * New LED added to front panel to indicate stand-by status * New color to better complement today's interior home decor * USB connectivity simplifies installation * 10/100BaseT Ethernet (auto-sensing) connectivity * Capable of downloading at speeds up to 100 times faster than a 28.8k analog phone modem* * Ethernet and USB are bridged allowing LAN traffic between USB device and Ethernet LAN * USB drivers WHQL certified for Windows 98/2000/Me/XP * Compatible with Windows 95/98/200/Me/NT/XP/Mac/UNIX * Supports up to 32 users (1 via USB and up to 31 via Ethernet, or 32 users on Ethernet) * No telephone lines needed -- always on, always connected
Motorola SURFboard® Cable Modem SB4200
With a SURFboard cable modem from Motorola, broadband Internet access is incredibly fast, always on, and always connected. That means no more dial-up, busy signals, or long, late nights downloading Internet homework information!
A great modem for today's broadband Internet, the SB4200 can support up to 32 users -- perfect for your home or small office. It's DOCSIS® 1.0 and 1.1 CableLabs® Certified?.
It could be either 1.0 or 1.1 since "SB4200" just by itself isn't enough information to go on. Go to the modem's webpage at http://192.168.100.1/ and click on the Help tab. Then look at the info it gives up in the top left. If that says SB4200-1.4.8.4-SCM01-NOSH, then it is Docsis 1.1 certified (and 1.0 also of course). If it says 0.4.3.3p or 0.4.4.0p, then it is an older Docsis 1.0 modem.
HTH Bob
Hello! It happens I am not lazy. I looked at both the DOCSIS=C2=AE homepage
and also the ones at Motorola, and then posted the question here.
