No simultaneous sessions on cable modem
Sep 28, 2004 2 Replies
I use a Scientific Atlanta Webstar cable modem and I face a peculiar problem. I can't seem to get simultaneous connections going.
Let me explain. If I use a dial-up then lets say the first download goes at 5Kbps. If I start another download, then both the downloads split the available bandwidth. But this doesn't happen with my cable connection. If I open multiple downloads to multiple sites, only one download is active at a time. I face this problem with Windows 2000 as well as Linux (2.4.26). With IE, Firefox, rsync and all other sorts of data transfer applications.
As another example, I am right now uploading data from the laptop at home to my PC in the office. The uploads are at 5-7Kbps but I can't ssh into my laptop at home from office at all!! ssh waits for a while and then says connection timed out.
My connection is 64kbps Up and 128kbps down. I use the USB port to connect the modem to my laptop. I have also tweaked the TCP window size on Windows and Linux is supposed to take care of that automatically. The only theory I have is that somehow the USB ethernet interface isn't able to multiplex connections. Unfortunately, I don't have a regular ethernet interface on my laptop to verify that. I also checked with my ISP and they said they haven't done any capping on active connections or anything of the sort. So any help will be appreciated.
Thanks,
Siddhartha
Your uploads are 7Kbytes/s or 7Kbits/s. If 7kbytes/s x 8bits/byte =
56kbits/sec, the upload is saturating your 64kbits/s upstream and there is no possibility of another upload. Note that with overhead, the actual transfer rate is more like 10total bits/8net bits, so the upstream could be nearly 70k total bits/sec including overhead. Q
I can't imagine any mechanism, that would cause that, other than limitations imposed by the server. However, that shouldn't be an issue with multiple sites.
