Wireless Networking wireless router + external hard disk connection
Subject Author Date
wireless router + external hard disk connection raghav 04-16-08
Posted by raghav on April 16, 2008, 10:08 am
I want to buy myself a router, that takes in a wan connection and
allows few lan connections. the Lan connections should be on ethernet
AND on wireless both.
I know, thats a simple thing to buy.
But, I want another feature from the router, which I cant seem to
find. (Or may be I am looking for a diff term). I want that my
External hard disk should be attached to the router so that its
available to the whole internal network as a network disk.
Is that possible ? are there products in market allowing something
like that ?
Or is my wish something absurd ? better ways of achieving the same
thing ?
I think AirPort Express/Extreme from Apple allow something like that.
I am a non-apple user and still want similar behaviour..
possible ?
too much to ask for ??
pls suggest ..
cheers
raghav..
Posted by SMS on April 16, 2008, 12:08 pm
raghav wrote:
> Hi,
Buy a drive enclosure with an Ethernet interface and plug it into the
router, i.e. a Coolmax CN-350, "http://tinyurl.com/5mbcom"
Or you can buy a complete drive with an Ethernet interface, i.e.
"http://tinyurl.com/6gaaj3"
I do exactly what you're doing.
Remember, the drive will always be on, it doesn't hibernate.
Posted by gene martinez on April 16, 2008, 2:33 pm
>Hi,
>like that ?
>thing ?
If you get a usb type drive you can take a look at something like the
Linksys NSLU2. I have it working with (2) usb drives. Another nice
thing is (if you need/want it) you can access the drives over the
internet.
Posted by Neill Massello on April 16, 2008, 6:13 pm
The file server built in to the Apple AirPort Extreme base station can
service both Windows (SMB) and Mac (AFP) clients. The AirPort Express
base station has a USB print server but no file server. Apple's Time
Capsule integrates an Extreme base station with an SATA hard drive and
power supply in a single box.
Posted by Bob Smith on April 17, 2008, 2:08 am
On Wed, 16 Apr 2008 07:08:50 -0700 (PDT), raghav
What your looking for is Network Attached Storage or commonly
called NAS devices.
The NAS device is basically a computer with a network card and
hard drives that you assign an IP address to and are able to
access the hard drives from any computer on the network
It's connected to the network via a cat5 cable which you can
plug into the router
check the link below. NAS storage is operating system flexible. They
usually all have the hard drives formatted with FAT32 (similar to the
USB convention) but you can format them for apple only or NTFS for
Windows XP and above.
http://www.pcmag.com/category2/0,1738,677853,00.asp
hope this helps, they are a little pricy and have various options
Bob
Roibert Smith Consulting
>Hi,
>like that ?
>thing ?
>possible ?
>pls suggest ..
>cheers
>raghav..
Similar ThreadsPosted
wireless router + external hard disk connection April 16, 2008, 10:08 am
Would like to find router to attach External Hard disk to that consistently works? April 3, 2008, 2:57 pm
Speed issues connecting hard disk through wireless router September 7, 2006, 3:31 am
Access to hard disk through router July 18, 2006, 8:34 am
doing a hard reset on a linksys router September 12, 2006, 8:18 am
help! Wireless router cannot get IP from external LAN DHCP November 16, 2005, 11:27 am
USB Hard drive Wireless ? January 11, 2007, 11:38 am
hard drive on my wireless network June 25, 2007, 2:56 pm
Different Wireless speeds on 2 hard drives October 8, 2007, 2:32 am
Instal disk for BIPAC-3020G December 8, 2007, 8:20 pm
How to optimize signal range for router with extra (9dBi) external antenna? July 4, 2006, 6:38 am
Control boot disk with Phoenix Award Bios 6.00 February 2, 2008, 2:56 pm
Re: Freeware to put "iPod touch" into disk storage mode on Windows PC? January 6, 2008, 12:16 am
Internet connection from Wired router to Wireless router ? September 28, 2006, 11:46 am
Mac Hard Drives, Help !!!! November 20, 2007, 5:08 pm
