Today is my day off so I had a little time to piddle. After seeing a couple of mods on the internet to put POE on a WRT54 I decided to build my own. The mods I saw involved hacking the box and I was not fond of this idea since especially since my case started to crack when I tried to get the halves apart. I picked up a couple of double wall connections from the Home Depot . I connected the #1 jack to the #2 jack on the same outlet except for the wires used for power. On these I connected the output of my wall wart power suppy.
On the other end I did the same connecting the power plug removed from same wall wart to the power leads on #1 jack. Realizing someone may cross up some wires and blow up their router like this I tried to do a little idiot proofing. AT the box used at the router I connected a little bridge rectifier removed from a modem board with the AC terminals gong to the line and the + and _ terminals going to the appropriate terminals on the power jack.
Yes I am being intentionally vague with these directions. Those with the appropriate amount of electronic savy should have no problems. This should work for about any wall wart powered device.
